Grease?
7/12/2019 2:50 AM
What is the best Grease to you when putting together a new complete out of the box?
7/12/2019 3:51 AM
Grease lightning.
7/12/2019 4:17 AM
I like park tools poly lube, but it is a little expensive
7/12/2019 4:50 AM
bulk waterproof marine grease. Bearings are sealed on most bikes
7/12/2019 5:00 AM
Thats what I currently use. I was worried when I first used it that it may be bad for the rubber seals and break them down. But it's three years later and I have had zero problems.
Are you ever supposed to open sealed bearings to clean them or not?
7/12/2019 5:34 AM
I’ve opened sealed bearings in the past. But they’re cheap enough to just replace. If they’re worn and feel rough, no amount of cleaning and greasing will fix em
7/12/2019 5:38 AM
Yeah I'm thinking it may not be worth the trouble. Plus they tend to last me a long time anyway. Sorry about hijacking your thread FitFamily.
7/12/2019 6:03 AM
Would that be okay in the cranks?
7/12/2019 7:35 AM
I use grease
7/12/2019 7:58 AM
Spongeworthy wrote:
I use grease
Spearmint grease?
7/12/2019 8:00 AM
Lol, is this becoming a forced meme?
7/12/2019 8:15 AM
spit
fack off
7/12/2019 8:54 AM
Any grease is better than none, but a bike specific grease is probably best. Park Tool, Phil Wood, etc
7/12/2019 10:12 AM
meatXloaf wrote:
Grease lightning.
Contrary to the "Bird", I hear Grease is the word.
7/12/2019 11:05 AM
I've popped BB sealed bearings open and cleaned and regreased them many times over the years. I had one BB outlast 3 sets of cranks and 2 frames. Got em from gritty to smooth (it was dirt causing the gritty feel) by pulling seals off both sides, then BLASTING with brake cleaner. Then I put one seal on and use wet chain lube (or ceramic if I am at the shop I part time at).
I am sick and tired of the "cliques" that this sport has recently developed. We should embrace the fact that we all ride a little kids bike, and not worry about the small details. When you take riding in its most basic form, we are all the same.
7/12/2019 12:07 PM
Spongeworthy wrote:
I use grease
p1p1092 wrote:
Spearmint grease?
All hail.
7/12/2019 12:08 PM
I use high temp bearing greasewith anti-seize. You can get a big tube of it for cheap at Home Depot.
7/12/2019 2:15 PM
I use it in my cranks no problems yet.
7/12/2019 2:22 PM
phil wood grease all dAyyy
7/12/2019 2:32 PM
And par ends for life!
7/13/2019 5:54 AM
Yes, I agree Dave. One can absolutely fix a gritty or rough feeling sealed bearing by doing exactly what you described. Just be careful to use a small pick to remove the seals and not to bend the metal band in the seal.
