Guard sprocket... run on the inside?
7/29/2019 3:15 PM
I picked up a guard sprocket. mostly because my current sprocket is 6+ years old and 2 of the teeth were bent but I bent them back, but also because I want the added protection for crooked grinds since sometimes when I slip out of crooks I end up sliding across my sprocket/chain.
my question is, for crooks do you think it would be better to run the guard on the inside (ala Ian Schwartz) because I feel like when I slip out and hit the sprocket/chain, it's being hit on that side instead of the outside. I don't run a 4th peg so I'm not worried about slipping out of opposite feebles and hitting it, just for crooks.
7/29/2019 4:32 PM
Depends on your side you do crooks on and what side your drivetrain is on.
7/29/2019 4:47 PM
RHD and ride left pegs doing crooks with my back left/front right
7/29/2019 6:05 PM
On the inside should be better, if it doesn't mess up your chain line.
7/29/2019 6:32 PM
yeah I'll have to make sure the chain line won't be off when I go to put it on, that was the other thing. I figured though I just needed reassurance, thanks!
7/29/2019 6:53 PM
Most modern frames barely clear a 28t let alone an inner guard. Hence why nobody bothers with them anymore.
But, yeah, inner guards are perfect for that if you've got the frame for it
7/29/2019 7:08 PM
welp never mind, just checked the chain line with it on the inside and it's way off. oh well, at least this will be a good future reference for someone who's going to bump it in 5 years to ask what guard sprocket they should get
7/29/2019 10:47 PM
I wanted to run a guard on the inside because it offers more protection for just about everything. But there’s no way you can get a decent chainline with it now. The amount of spacers just for the sprocket to clear the chain stay is ridiculous
7/29/2019 10:57 PM
The guard cleared my chain stay just fine, but the teeth were too far out of line from the driver. oh well, not a huuge deal
