Gyro help!
2/8/2014 8:16 AM
About a month ago I installed an Odyssey gyro on my Kink Whip. The instructions stated that I needed a certain length of fork tube available to make the brake work correctly. My tolerances were a bit under, so figured I could make it work anyway.
I was able to get everything dialed in but couldn't ride due to weather. I took it out for a spin yesterday and I do not have the braking power I should have, almost like I don't have enough travel in the gyro to lock up. Is there anything I can do, or should I remove the gyro?
Just an old guy riding the toys I couldn't afford 25 years ago!!
2/8/2014 9:18 AM
Do you have pictures? I'm guessing the gyro is hitting the top/upper plate which is preventing you from pulling the cable further?
2/8/2014 9:32 AM
I think tha tyoum should adjust the lever, the brake and all that.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
2/8/2014 7:59 PM
pnj wrote:
Do you have pictures? I'm guessing the gyro is hitting the top/upper plate which is preventing you from pulling the cable ...more
Most likely this if you cant engage the brakes fully
My Fit
