Gyrooooooooooo
10/30/2018 7:58 PM
Before I get hate, it's not rattling.
So my gyro is all weird when I move the bars and shit and idk why lol. Here you go. Turn up the volume becasue I tell what's going on in the backround.
Thanks y'all!smile
10/31/2018 3:04 AM
For real? No one?
Lol
10/31/2018 3:14 AM
Sounds like aids, you need a new bike
10/31/2018 3:18 AM
Have you changed your set-up again???
10/31/2018 3:28 AM
Um no lol
10/31/2018 4:55 AM
Do your brakes work? If so don't worry about it jeez
10/31/2018 5:08 AM
Hey, I'm trying!
Instagram
10/31/2018 5:10 AM
Thanks y'all!smile
Is your spring tension the same on both brake arms? Only thing I can think of (without seeing every angle as it happens...up close) is that when the cables of the gyro are in line (handlebars straight), there is equal pressure (cable to cable) as can be. When you turn your bars 90 degrees, the cables are no longer in line & there is room for discrepancy as the gyro is now free to allow any variation you may have in your spring tension & cable adjustments.
10/31/2018 5:10 AM
Guess I can't get a for real answer. Thanks y'all
10/31/2018 5:13 AM
Thanks y'all!smile
Are you able to see if your gyro does the same thing?
Because this happens when the bars are 90 degrees and I pull the brake. But if I turn the bars 90 degrees and don't pull the lever then they stay even...
10/31/2018 5:24 AM
Edited Date/Time: 10/31/2018 6:11 AM
Thanks y'all!smile
I can't at the moment.... as I'm working. I can look when I get home. But I am sure it is caused by a combination of your cable adjustments and the spring tension.
Also, take a look at your gyro plate & make sure that when your bars are 100% straight (or as close as can be) that it is in line with the gyro tabs. If they are off a bit, it could be that the cable tension will change in the same sort of fashion as if your cables were out of adjustment and you turned your bars (similar to another post the other day where his gyro "clicked" when he spun his bars).
10/31/2018 5:32 AM
Have you ever read The Princess and the Pea, Jake?
10/31/2018 5:41 AM
Gyro flop, meaning you have a few micro adjustments to make at the barrel and then it will stop
10/31/2018 5:41 AM
Ok I'll take a look when I get home
10/31/2018 6:37 AM
That's just an adjustment issue. Like Mishinn said, fiddle around with the barrel adjusters and spring tensions.
Something is just slightly off.
10/31/2018 6:54 AM
I think we need another brake thread
10/31/2018 6:56 AM
JAKE BRAKE!
10/31/2018 6:58 AM
Edited Date/Time: 10/31/2018 6:58 AM
TheDarkEnergist wrote:
JAKE BRAKE!
Lollaughing
10/31/2018 8:08 AM
Simple solution
brakeless tongue
10/31/2018 8:54 AM
dead goon wrote:
Simple solution
brakeless tongue
I REFUUUUUUUUUUUUUUSE!!
10/31/2018 9:01 AM
He does have a point tho. How many brake problem threads have you seen from me or dead goon for example?wink
10/31/2018 9:08 AM
But....HOW DO YOU STOP!?
Hey, I'm trying!
Instagram
10/31/2018 9:45 AM
I don't, I just keep movingtongue
10/31/2018 10:14 AM
On coping. While doing a 540 hurricane.
10/31/2018 10:16 AM
Oh yeah, well, well, well.... NO BRAKES ARE GAY!!!
10/31/2018 11:02 AM
dead goon wrote:
Simple solution
brakeless tongue
It’s just a barrel adjustment thing. I really suggest dual lower cables if you are not running them already. Works better and you can eliminate the slop by just adjusting 1 thing on 1 side. I don’t mind stock upper cables but lower I have to run dual. And don’t get some companies dual cables. Buy 2 good cables and 2 knarps, then cut and install. If you don’t run duals. Black Ops has a London mod clone for $4.00
10/31/2018 11:15 AM
Edited Date/Time: 10/31/2018 11:16 AM
Some of them might be. Statistically, a few of us regular users are gay too
10/31/2018 12:40 PM
I think we need to take a brake from all of this. Sorry BREAK.
Instagram: @scootereyn
10/31/2018 1:20 PM
"Well now, they call me the breeze
I keep blowin' down the road"
10/31/2018 1:43 PM
I already got dual uppers and lowers
