First of all id like to state that Im not an idiot when it comes to bmx hubs, ive rebuilt multiple profile/maderas and many other brands and makes/models. This one imparticular is the Proper K7 cassete hub. 9t driver, uses a shim system and its all working fine, everything. I bought new bearings for it and i started taking this bad boy apart. I got all the nuts and bearings out except for the hubshell bearings next to the driver. It seems that the teeth that the driver bites onto is covering the hubshell bearing so it will not come out. I already hammered on it before realizing that it wasnt going to come out, the shell isnt bent, nothings too far gone. But the bearing is frozen now and I NEED to get it out. Any ideas helpful, dont be afraid to say whatever you think it may be, i can use literally any ideas at this point. If you have the hub and have had this issue before and know exactly how to get the bearing out, please text and call me ASAP. 414 617 3945.
Please please please somebody has to have gone through this before. If nobody gives me a good answer ill take it to my LBS tomorrow and have them check it out. But until then the only way I can see getting this out is by taking out the drivers teeth ring thing thats screwed into the hubshell.
HELP!!!
