HELP @ onyx cranks!!
5/25/2012 9:40 AM
anyone knows here how to remove eclat onyx cranks without crank puller in a safe way??
5/25/2012 9:43 AM
Yeah.
5/25/2012 10:08 AM
put your butt in the hole
follow me on instagram! @neck_brace
also go like my media page on facebook! jiraffe media
also follow jiraffe media on insta! @jiraffe_media
5/25/2012 8:37 PM
ill put my spindle to ur asshole u stupid moron!
5/25/2012 8:40 PM
I just came twice, moar?
5/25/2012 8:42 PM
5/25/2012 8:45 PM
you cover it with super glue then when it drys put more on then put lock tight on then.... beat the fuck out of it with a metal hammer...
MY SEXY BIKE CHECK!
sunny.jomofo, even more of a bitch than Dane wild!
if you need to talk to me text me 1-734-301-6545
on the legit list
35+ clean refs
2/5/2017 4:31 PM
I'm having the same problem. Need legit answers. I don't even know if mine are the 2pc versions. If it is I broke a ratchet for nothing :/
2/5/2017 5:20 PM
Use a punch, or screwdriver to pound out the spindle. Or screw out the bolts almost all the way, and tap the end with a hammer. Lots of smart asses around today, but they aren't smart or funny. Go figure.
2/5/2017 5:41 PM
You only want to thread the bolt out maybe one or 2 turns and then loosen as needed. Threading the bolt out too far is a very easy way to damage your threads or bend/break the bolt. You should also put something between the hammer and the bolt as you can quite easily deform the head enough that it won't fit back into the crank.
2/5/2017 5:57 PM
Seems like the smartasses were especially around like five years ago tongue wink
Frmrly BmxBos
2/5/2017 6:45 PM
Don't bump 5 year old threads.... just start a new one.
Ride hard or Ride home.
Pink N’ Pretty
Instagram
@tarsales
2/5/2017 6:55 PM
I came a third time. plz moar
2/5/2017 8:38 PM
Edited Date/Time: 2/5/2017 8:41 PM
Lol yup your right. I didn't notice that, my mistake.
If you tap Very lightly you should be fine. A couple of screws probably won't get it far enough. Using a punch is your safest bet though.
2/5/2017 8:52 PM
Edited Date/Time: 2/5/2017 8:53 PM
I'd always avoid screwing the bolt out too far, and then when I've moved the spindle enough that the bolt bottoms out I'll loosen it further and then go back to tapping it out. My 2 preferred ways are are using a big lump of bar stock as a punch or using a gear puller.
2/6/2017 6:05 AM
Honestly this is one of the few times I think bumping this thread was okay...
