Headset dustcover
1/17/2016 4:21 PM
I have an integrated Fly headset, and today i noticed my dustcover for the bottom has separated from the bearing. Is this something i should be concerned about? My concern is the life of the bearing will be limited due to dirt and grime. Is there a way to re-fix the dust cover to the bearing without ruining the bearing? I thought about using the race that came with the headset in hopes that it will seal it up tight against the bearing. The only problem with that is i have an oddy r-32 fork, so having one race ontop of another might not be the best idea. I read in other threads about the possible danger of two races ontop of eachother. Should i give it a go or is the dust cover not something i should really be concerned about?
Refs: Josh_Ketcham, mykneeshurt (x2), Brian_Griffin, aaron.samuel.green
1/17/2016 4:35 PM
my friend rode his for months and months with it like that but if you can afford one it wont hurt
ride bikes, have fun
STRAIGHT OUTTA STRAYA
1/17/2016 6:52 PM
That just looks like the rubber seal, so pop it back in and it'll be fine
definitely pop it back in though otherwise dirt and shit will get in there
1/17/2016 9:43 PM
Just put it back on. If not I've rode bearings like that for months and they are still fine. But I recommend putting it back on so it doesn't get dirty or anything.
1/17/2016 10:19 PM
Yeah give it a clean and push a bit of grease in, then push it back in
1/18/2016 1:47 PM
Thanks for the responses guys. It's an easy fix.
1/18/2016 4:19 PM
You're welcome.
1/19/2016 1:10 PM
This.
I have some headset bearings that I got YEARS ago, still going strong.
