Headset having a shitload of friction?
5/27/2013 11:05 AM
I tightened my headset until i felt that change in tightness from fallout loose to just right. And when i move my bars side to side i feel slight friction. What should i do? You can almost hear it the friction going whoosh whoosh. What do?
I ride for my papou.
Cats got 9 lives I got four.
5/27/2013 11:08 AM
sounds like bad bearings to me.
5/27/2013 11:10 AM
Are standard headset bearings bad?
5/27/2013 11:11 AM
Illuminati
5/27/2013 11:17 AM
Any bearing can be bad or go bad. does your bike have unsealed cage bearings or integrated?
5/27/2013 11:22 AM
Ummm how would i check this out?
5/27/2013 11:24 AM
-_- What frame do you have?
5/27/2013 11:27 AM
Shit load of grease usually works.
I got refs
5/27/2013 11:32 AM
A 2011 mirraco axium. It has a standard headset if thats what your asking... You should make more of those how-tos
5/27/2013 12:00 PM
i wish i had a bike with a standard headset to do one with. all my shits integrated or sealed road shit. its almost the same thing though just load the races with grease, install bearings, more grease, Tighten compression bolt ,then stem bolts.
5/27/2013 12:16 PM
I had exactly the same problem working on a bike today, what you need is a tiny little ring of metal under the headset cap. It just lifts the cap slightly off the head tube. Your headset dust cap is grinding on the head tube thus creating the tightness & grinding you're describing.
5/27/2013 1:23 PM
Topsey wrote:
I had exactly the same problem working on a bike today, what you need is a tiny little ring of metal under the headset cap. It ...more
Where do i get this? And do you mean the fork bolt cap thing?
5/27/2013 1:28 PM
Nope, not a lot of headsets come with them. NOT your compression bolt (Fork Bolt) If you go to a decent bike shop & explain the issue & that you need a washer or two to go under your headset dust cap they will more than likely for a couple whatever it is in America cents or whatever? They really shouldn't be a lot. Seriously over here IF a shop has them (Which the should) They will be like 10 pence or so per washer here.
5/27/2013 9:12 PM
Topsey wrote:
Nope, not a lot of headsets come with them. NOT your compression bolt (Fork Bolt) If you go to a decent bike shop & ...more
My lbs had no idea... Can you send me a link to a home depot item?
5/27/2013 9:32 PM
Edited Date/Time: 5/27/2013 9:33 PM
It looks just like headset spacers but is barely .4mm thick. But they are unsealed so they could just be taking a shit on you. Fsa pig headsets will replace your cups with cups to accept an integrated headset.
http://www.danscomp.com/products/301057/FSA_Pig_Headset_(Sealed).html
There's a link.
It'll replace the black things in this picture and instead of the bearings you see here, they will be integrated
For 45 bucks, your making your fork options better, you bike more maintainable, smoother, and it comes with a headset so your basically payin 20 for the cups and 25 for the bearings.
5/27/2013 9:48 PM
future FBM wrote:
It looks just like headset spacers but is barely .4mm thick. But they are unsealed so they could just be taking a shit on you. ...more
What size are headset spacers? I just ordered a fsa plastic in 1 1/8 is that alright?
5/27/2013 9:53 PM
You got the right size, but I don't think this is a spacer issue man. Do you have the top and bottom races in?
5/27/2013 9:57 PM
Im positive. I will ask the nigga at home depot for a itty bitty spacer in 1/8 to put between? The top cap of the headset and the bottom cap of the headset?
5/27/2013 10:02 PM
SickDude wrote:
Im positive. I will ask the nigga at home depot for a itty bitty spacer in 1/8 to put between? The top cap of the headset and ...more
It's a peice that shims between the bearings and fork tube. You need those even In sealed
5/27/2013 10:03 PM
Post a pic im lost lol
