Is this to much space ? If so is it ok to take my headset cap off?
Yeah, bit too much dead space. Take spacers out, if you can. It’s not entirely a good idea to run without a compression cap either.
I have no spacers I guess I’ll have to get new forks
If the top pinch bolt fully laps onto the fork tube, it's "probably" ok. If the fork is cut below the top pinch bolt, I wouldn't run it.If in doubt, get a new fork.
Remember when you could ride all day and not be sore for a week?
Instagram: @theothermaj
I just ordered a thinner one the stranger ballast one so hopefully that works I’m sanding it down now so hopefully that works
The pic makes me think it's the second one. There is lettering just like the second picture, in his picture. Either way it seems kind of odd to me. The second one looks like there is a spacer on top. My Eastern looks a bit like that but it's 2 pieces. And yeah, somehow cutting down or sanding down the top of that second one seems like it would work
Although that's gotta be like mine. Those are all separate pieces eh? If all you have is the flat piece on the bottom of that, then it seems like the forks are cut down a bit more than they should be...… I wondered about this the other day. You could technically just plop the stem on top of a bare bearing if you really wanted low, eh? I'm not sure how much of it would be covered though.
I have the second one and I sanded it done last night gonna check it out as soon as I go outside
Can you give us a side shot? I'm just trying to understand how tall the top cap actually is. Seems like there are different types out there....
Those are uncut BSD Acid forks? I swear they came way longer.
What’s the measure of your headtube?
157 they say I need 162mm or 164 mm to be safe
5” headtube tallboy frame
That's why. I saw your headtube and figured it was an S&M Tallboy. You need a fork with a longer steerer tube.
-Sheldon on Adam22
"The only future for BMX"
-jbales on mafiaBIKES
-adamnmexican
You could remove the dust cap and use a thin spacer in its place. The dust cap isn't strictly necessary; just a good idea, if it fits.
Joe_Mackin 3 wrote:
I’ll try that it fits perfect without the cap also but I will try spacers
I'd just put one slim spacer underneath the stem to stop the wedge from gouging it and to be sure that when the wedge compresses down, your stem doesn't hit the frame. You also don't want the steerer tube coming up to the top of the stem as that will prevent you from tensioning the headset. A small gap of 3 or 4mm should ensure that you have no issues with tensioning the headset.
I’ll do that then thanks
Is there a reason they make such a tall headtube?
Aesthetics. It removes the need for the big stack of headset spacers people used to run. A lot of companies started making their frames like that, I'd say about 2 or 3 years ago.
To phrase it a different way, you can set your stem higher while using fewer spacers. You could see it as part of the taller bars trend.
To eliminate the use of spacers but I guess they forgot about steer tube height and shit
Back when the Acid forks were made, tall headtubes and bars weren’t in style.
