Would this head set
Fit me properly I have a headset that has caged ball bearing and it wont work properly it wobbles and yes I had tightened my headset but it won't work could u please help meee
Would this head set
No, as unsealed integrated headsets don't exist. You can buy a cup that converts a standard headtube to integrated. Or just buy a decent sealed headset
your bearing probably separated, which is common, and now half of it is inside your head tube and the other half is above the bearing cage. take it all out and play with it till it works again.usually they can be pieced back together until the bearing cage is finally mangled or broke into pieces
wallride a bus everyday
Brayden_Buckingham wrote:If the headtube is intergrated yes
I'm not sure is this integrated
