Headtube angle vs fork offset
7/21/2018 6:59 PM
How many millimeters of fork offset is equal to .5 degrees of head angle? I heard somewhere that .5* is equal to about 3mm of offset. Is this correct? I've been trying to figure this out for a while now
7/21/2018 7:16 PM
doesnt matter much honestly ride 75.5 with 13-15mm forks ull be fine i ride 75.75 with 13mm forks its not crazy
7/21/2018 7:30 PM
Edited Date/Time: 7/21/2018 7:34 PM
.5° hta is equal to 7mm fork offset...
So 1 degree is equal to 14mm...
So 75° hta with 25mm offset fork is equal to 75.5° hta with 32mm offset forks...
"hta" stands for, Head Tube Angle in case you didn't know..
At least that's what I've read. It could be wrong though. But I'm not sure....
7/21/2018 7:47 PM
I was possibly wanting to do 76.25 hta with 33mm forks. You think that would be stable enough?
7/22/2018 2:27 AM
Good luck it’s going to be twitching all over at first. With 33mm offset it will be hard to get that angle 17-20 maybe
7/22/2018 3:38 AM
Seems a bit backward to me, you'd be much better off with a mellower headangle and steeper forks
7/22/2018 6:43 AM
No it's just that the frame I'm looking into has a really steep hta and I'm just trying to make it as mellow as possible lol. I like everything about the frame except possibly the hta
7/22/2018 7:19 AM
What frame are you looking at? The Doomsayer? Just find another frame with the same geo but with a mellower head tube... problem solved
7/22/2018 7:36 AM
*buys the most responsive frame on the market, just to mellow it out* wassat
7/22/2018 8:30 AM
jiminyu wrote:
No it's just that the frame I'm looking into has a really steep hta and I'm just trying to make it as mellow as possible lol. ...more
Shorter fork offset makes for better steering whilst being just as responsive. Steeper headangle makes the steering twitchier. There's some science that George French went into that I can't be bothered to find that explains it all.
There's literally hundreds of frames on the market. I'm pretty sure you'll be able to find one with the same geometry but sightly slacker ha
7/22/2018 12:59 PM
Shorter fork offset makes for better steering whilst being just as responsive. Steeper headangle makes the steering twitchier. ...more
easy enough to view it like a drift car, a jzx100 has a longer wheel base than say a miata. jzx100 has more stability and easier to drift where the miata is twitcher because shorter wheelbase so its harder to hold the angle.
even with that the 76.25 i would prolly ride 15mm offset forks
7/22/2018 3:11 PM
Hahahaha
7/22/2018 3:12 PM
Yeah I decided that I want something mellower. The doomsayer is just too much lol.
7/22/2018 3:13 PM
easy enough to view it like a drift car, a jzx100 has a longer wheel base than say a miata. jzx100 has more stability and ...more
Bruh holy shit ??. You would make a 90 degree turn just by slightly tilting the bars lol
7/22/2018 6:13 PM
??? so true
Go with 75-75.25 and then adjust with forks and you are set. Friend is running a 15 ofset forgot his HT but it equals near 75.75 with the forks
