Help!
3/9/2013 3:53 PM
So, when i put my cranks on my frame and tighten them and move them it is kinda hard to do it. Now i'm pretty sure this isn't right so idk whats up. I know it probably sounds dumb but i don't know what to do. And my sprocket, chain keeps getting loose then tight. :/ wtf.
3/9/2013 4:05 PM
probaby bent your sprocket thats why your chain gets tight and loose
3/9/2013 4:06 PM
Alright.
3/9/2013 4:20 PM
Edited Date/Time: 3/9/2013 4:26 PM
And my new sprocket will be here wednesday so would it be ok to ride a bent sprocket for a little bit or no? and this could be something also. when i tighten my sprocket to my cranks there is a little space in between the spindle and the sprocket could it just be like that because i don't have the right spacer on? And what about the cranks?
3/9/2013 5:13 PM
My sprocket got bent what I did was put it on a bench put a block of wood on top got a hammer an managed to flatten it nice tapping slowly bending it back an it worked try that mate an you said your getting a new sprocket anyways so whats the worst that cold happen?
3/9/2013 5:38 PM
lilchrissyy wrote:
My sprocket got bent what I did was put it on a bench put a block of wood on top got a hammer an managed to flatten it nice ...more
Idk.. But my luck it the worst.
3/9/2013 6:18 PM
yeah, you could just pound it flat again... and im sure youd be fine for a couple days... if anything itll break just a link or two
skooter... dont be a pussy
3/9/2013 6:26 PM
Your sprocket and driver could be bent or dented or either one.
Just take a look at both of them and you may need to get a new chain now because of tight spots that were created
3/9/2013 7:24 PM
Just take a look at both of them and you may need to get a ...more
I got a new chain today. I guess i'll just cruse and do flat stuff. thanks.
