Ok so i have this problem with my chain comming loose and my back wheel isn't moving up. I don't know what to do.
explain more....
Refs:
Traded: tomdon
n-dür on facebook
When i ride a little bit it the chain comes loose. I think the problem is with the sprocket? I have no clue.
does it have a tight spot?
Refs:
Traded: tomdon
n-dür on facebook
Mikel8149 wrote:When i ride a little bit it the chain comes loose. I think the problem is with the sprocket? I have no clue.
SnM An1mal wrote:does it have a tight spot?
It's a mds and its new. No tight spot.
idk.
Refs:
Traded: tomdon
n-dür on facebook
Do you use washers in between the dropouts & axle nut? If no, put some in and try it then. Sometimes your wheel will slip if you don't have them
sundaybmxRR wrote:Do you use washers in between the dropouts & axle nut? If no, put some in and try it then. Sometimes your wheel will slip ...more
No. I'll try it.
