Help with S&M of Fit forks and front brake
6/28/2015 5:08 PM
I want to add a front brake to my Fit CR24 using a Potts mod style thru the stem cable. The problem is, I have the small H10 compression bolt with a washer welded inside the fork.
The bolt is a 10x1.25. It is hollow, but the hole in maybe 2mm tops.
http://www.empirebmx.com/sm-fork-compression-bolt
Where do I get a hollow one that the cable will fit thru? The link above looks like what I have. I don't want to drill it out as I think that the Allen key hole is smaller then the cable hole.
Any ideas? I have seen pics of the Fit with a front brake, but they are in threads from 2010 and I didn't want to bump old dead threads. I have been searching like crazy. I would even take a wrench Potts mod bolt at this point, but would prefer something that looks decent.
Thanks for you help.
6/28/2015 6:38 PM
get new forks or go without the potts mod.....sorry sad
6/28/2015 7:48 PM
Edited Date/Time: 6/28/2015 7:51 PM
You could grind out the washer and use this or drill and tap the washer in your fork for the bolt and forget the star nut.
Instagram @tkeck74
6/29/2015 5:36 AM
New forks are out of the question. Too much $$.
I was thinking about drilling and retapping the hold int he welded in washer. I should have that size tap already.
So if I were to mess up the retap, I could use that star washer instread?
thanks for the help.
