Homemade Bike Parts/Accesories
9/12/2015 10:40 PM
What are some homemade bike parts and/or accessories you've seen, heard of, or made yourself? I never even thought to make anything really then I saw a video of using a street hockey ball for a hub guard. Even if you'd never use it still creative.
9/12/2015 10:48 PM
cracked frame? cut off the rear, bolt it to a wood base, bongo you have a truing stand.
9/12/2015 11:03 PM
I made a wooden hub guard on a lathe in 8th grade shop
9/13/2015 9:29 AM
coathanger brake mod which ill be doing since my flybrakes springhanger decided to snap after light use
9/14/2015 6:28 AM
This actually kicks a lot of ass.
I have old frames at my moms.
Guess who is making a truing stand?
I knew of old forks as one though.
I have made hub guards (before they truly existed) our of thicker steel plating. Drill it out for the axle size, and then put it between the frame and peg.
9/14/2015 7:15 AM
Rob ridge made a decade plate for his frame from am old stem
9/14/2015 8:04 AM
Not really a "part", but I put jam nuts on my rear axle bolts, because there was less than 1/8" of female axle sticking out to rest on the dropouts. I just had to grind them down a bit so they were the same width as the space, the 3/8x24 nut itself was a perfect fit in the 14mm dropout slot.
9/14/2015 9:07 AM
I also have my dual lower cables cross behind the seat tube, and rather than have them basically cut the frame, I put little pieces of housing over the cables and run a couple zip ties to hold it. That way I get better brake actuation as it pulls on a MUCH closer axis to the brake arm swing.
9/14/2015 11:16 AM
dave lawrence wrote:
I also have my dual lower cables cross behind the seat tube, and rather than have them basically cut the frame, I put little ...more
Picture please....I want to change mine up too. I don't like the way it carves into the seat tube either.
9/14/2015 11:34 AM
It's in my Profile, but here:
9/14/2015 11:42 AM
I actually just made this because my fly springhanger broke just stopping not even hardPhoto
9/14/2015 10:42 PM
One i did a while back, mounted the dual gyro cables higher up on the frame, angled the london mod for a straighter, smoother pull and cut the cables for a light bend, like butter and stops on the dot.
