5/11/2013 5:05 PM
Edited Date/Time: 5/11/2013 5:09 PM
brandon.hankinson.3 wrote:
it was fine b4 i unlaced off old hub, both were. this was a stolen revolver complete wheel that i put the front hub with a ...more
it was fine b4 i unlaced off old hub, both were. this was a stolen revolver complete wheel that i put the front hub with a hazard that was straight when i got off my friend and this stolen rim was straight
You may have ovalized it yourself when trying to true it. Hop is a bitch to get out too once it settles in. It can even cause permanent deformation to the rim.. so might have to just live with it if it's not that bad.
What happened is when you went through tightening up the spokes, you probably tightened a few farther than the rest. So there can be 1-3 spokes that are pulling harder than the rest; bringing down that section of the rim, causing it to hop. Thats why you've got to take your time and make sure every spoke is pulling with the roughly the same amount of force all the way around. Put the wheel on your frame and spin it. Grab a pencil and hold it flat on the rim as it spins. Let the rim scrape the pencil. Watch very closely and you can find where the hop is. Spin it slow, locate the hop and you'll be able to locate the exact spoke that is pulling too hard. (or not pulling enough) It's just a game of evening spoke force.
For future reference:
I go around 2-4 times. The first pass just half turns, the second gets the spokes to grab the flange, the third to snug them up a bit, and the fourth to actually true it up. Then some finishing touches and it's done. Take your time.
