How do I make the bore hole in my sprocket bigger?
11/10/2018 5:58 PM
What are some ways to make the bore hole in a sprocket bigger?
11/10/2018 6:07 PM
You cant. At least not without like maybe a proper machine to do it.
Get a new sprocket if you need a bigger bore.
11/10/2018 6:24 PM
chainsaw and dynamite
11/10/2018 6:35 PM
Why though?
You can use sandpaper without a problem if you're only increasing the size by less than half a mm but any more and you risk losing the concentricity of the hole, which causes problems for the rest of your drivetrain over time.
11/11/2018 6:45 AM
Drill press and a self centering drill bit could work, but even then there's a very high possibility of fucking up. A sprocket is one of the parts you don't want to be "pretty close"
11/11/2018 8:07 AM
as others have said, unless you're a machinist, don't
11/11/2018 12:43 PM
A milling machine, a dial indicator, and an end mill. Without having an exact side end mill, you'll need to circle interpolate the hole. If all that is confusing to you, buy a new sprocket.
