I want my bike dialed but I don't really know how to work on my bike. I have a family owned shop a mile from my house? How much should they charge me? I do not know if it would be cheaper to go into the next city over to get it fixed
13 years old
13 years old
About tree fiddy
FBM Pizza Beer Roast Machine
You're better off doing it yourself its cheaper and its a good learning experience. All it is is basically tightening bolts have the right spacers and alignment grease up bearings and such. If you are running brakes just make sure you tighten the cable hanger at the rear and have all the bolts snug tight to your likings. Pretty much it
Pretty sure my LBS charges 60$ for basically everything but bearings and brake cables , I believe 100$ for everything you need but that's on any bikes , so obviously DH bikes will have more to work on for example , you can do everything yourself for a BMX bike really.
The shop I work at charges $20 for a basic tune up which includes snugging up bolts/nuts, adjusting bearings, re-greasing things if needed, lubing the chain, and truing the wheels. If they needed a part though gear/brake cable, we'd obviously add that price on. And if they needed like a new bottom bracket put in, and the crank arm was seized to the spindle, that usually adds a couple bucks onto the price as well for labor. Typically we do things like that by the job though.
Then again, think about it. If the shop closest to you charged say, $30 for a tune up, and the city over from you charged say, $20, and is like 50 some miles away, that's also a good bit of gas money to factor in as well since it'd be going there, and back (most likely two trips since you'd probably have to leave your bike there, then go back to get it) which could end up costing a lot more than just going to the one closest to you.
Before I knew what I was doing, my lbs charged me like $30 to tighten a not for an unsealed BB. Total ripoff, since it only takes like 30 seconds and absolutely no effort.
IG: therealclintvessey
{\_/}
Would it be better to go over to my friends house and have him do it? His bike is dialed so i assume he can dial mine.
13 years old
My buddy's a mechanic at a gm chev dealer and they'll charge a full hour for a job that takes 2 minutes and all the dealers run on the same system, in the land of mechanics it's not the labour it's the knowledge of how to fix stuff is what your paying for
Yup, have him teach you how to do it too.
IG
@curtis_cantbmxwell
the expensive shop by me charges 50 for a tuneup
honestly, id just do it myself or with a friend if your friend is better with bikes, and pick up what you can from watching him do it
skooter... dont be a pussy
It's always a good time working on and cleaning bikes with a fellow rider and a case of beer
Save you money and buy some tools it’s a investment for future repairs. If your on a tight budget just get a 17mm extended socket and ratchet and a 6mm Allen wrench. That will get you though most everything. I’d like to add that tools is something every grown man should own so maybe it’s time to invest in some grown up shit
