How to 990mount bolts with stripped heads??
10/9/2016 11:17 AM
Got a frame with 990 mounts on it but the Allen heads are stripped inside sooo I can't take them off. Anyone deal with this before and know how get them off?
10/9/2016 11:34 AM
go to hardware store and ask for some reverse drill bits about same size.... drill em out
10/9/2016 12:01 PM
Almost. A reverse thread drill bit will just drill a hole into it. You need an easy out (or ez out). Which is like a drill bit with a reverse thread, but it gets wider. You need to drill a small hole into the bolt first. Then use the easy out
10/9/2016 3:46 PM
One of the few things that actually works as described on tv (as long as you have a drill):
I've used it on a bunch of stripped heads and it hasn't failed me yet. Can get them at Wal-Mart, Home Depot, ect.
10/9/2016 5:48 PM
Run brakes
10/9/2016 7:10 PM
Try putting a but of duct tape in head and jam the Allen in, saw this on you tube awhile back
10/9/2016 9:23 PM
Thanks. It's the classic style where the actual mount has threads on it. I just used a vice grip directly on the mount and twisted it off. Left teeth marks in the mounts but it's not like I was gonna use them.
I'll have to try the duct tape trick if I come across stripped heads again.
10/10/2016 2:28 PM
adamnmexican wrote:
Run brakes
I second this.
