Copyright Bmx-forum.com
Buy:
-1 piece of pressure treated plywood 4x4 that is 3/4"thick about $35
-A bunch of cheap 2x4's maby $15 or $20?
-2, 8 foot ieces of 1/4" thick 2" wide angled steel (for edge) $20-$25 (each)
-Some paint to protect the wood and make it look cool =) $3-$10
-Screws (1" to 1 1/2") $10?
total: $100 (about)
Dimentions:
The box will be 8 feet long (part you grind). It will be 2 feet wide. And 1 foot high.
Note:
-It wont be the highest grind box but it is enough to grind and only uses 1 piece of plywood
-Ask if the guys at the place you buy the wood if they can cut the plywood (2 1'x8' pieces, 1 2x8 piece)
-you abviously need to drill through the angled iron
-if its your first time buildin stuff just do both sides angled iron but you can do one side with a rail.
-put the ribs (2x4's) every foot underneath the top plywood and put some supports elswhere.
tools:
-saw (preferably electric)
-drill/electric screw driver type device haha
maby other tools also but i can't think right now
here is what it should look like:
You could cut off your penis to save some extra weight...
