How to fix a tight chain?
1/27/2015 1:52 AM
How do you fix a tight chain that hardly works?
1/27/2015 2:26 AM
Heres the chainPhoto
1/27/2015 2:59 AM
Seaman, lots and lots of seaman.
NEW Bike check
Raw Clips Edit
1/27/2015 3:01 AM
Is that some sort of lube?
1/27/2015 3:36 AM
Edited Date/Time: 1/27/2015 3:37 AM
Grease lots of grease everywhere use glove if you want cause is gonna be a mess, then clean the visible side and try it. itll do. press the grease into the tiny parts
1/27/2015 4:41 AM
I hear it can be used as a lube, but usually it requires lube to acquire
NEW Bike check
Raw Clips Edit
1/27/2015 8:17 AM
Lube it. Then install it. Then ride. In no particular order.
What part is tight? Does it have stiff spots? You can work those areas side to side a touch (not the way it bendson the pin) and that helps loosen them up a tad.
1/27/2015 8:29 AM
If it's tight because of rust soak it in diesel
1/27/2015 8:58 AM
Edited Date/Time: 1/27/2015 9:00 AM
find the tight spot, and take an extra spoke and pass it through the links around the tight join and kinda just press it agasint the sides of the chain in both directions, you'll just take some pressure off the roller thats causing teh tight spot. also oil will help make it smoother.
if the whole thing is tight, just drop it in a container with some oil, and let it soak for a few hours. take it out, rinse it, rub some triflow on, and install. or install and then triflow, working with a slippery chain can sometimes be a pain in the ass, but personally i find its better because the chain is more evenly lubricated.
"The D.O.P.S. System"
DK, Odyssey, Profile, Shadow.
check out my bike check
@ethanbrackett
1/27/2015 4:46 PM
I'll try that.
1/27/2015 5:39 PM
I'll try that.
One of my best friends is a mechanic and everytime he's got something stuck with rust he just soaks it or runs diesel through it
