How to do the 360
8/18/2019 2:12 PM
I am to point where i can land my 180s 10/10 and roll back almost all the time so i decided that its time to learn the 360. So this what i got from the first day and i got to say I got STOMPED. Can somebody help me with this trick? Tips what I am doing what I must do etc.
Cheers
8/18/2019 2:47 PM
Go a bit faster and pull harder.
8/18/2019 2:52 PM
Pull harder at the start?
8/18/2019 2:59 PM
Yep. You could also try pivoting at the end.
8/18/2019 3:39 PM
Would I pivot using pedal presusre?
8/18/2019 3:49 PM
If you have a cassette. Pedal pressure is really bad for the large drive side bearing on freecoasters.
8/18/2019 4:01 PM
I am on cassete
8/18/2019 4:18 PM
Try it off a jump get more air time
8/18/2019 4:32 PM
I used to be landing exactly the same as you are. I was only doing a 180 with extra carve, I found I needed to hop way more too and that's what got me to land them.
Also if you sort of scoop your body into it sort of helps. Dip your body down at the very start of the carve to preload as much as possible, then as you get to the end of the carve launch your body up and just pull up on the bars
8/18/2019 5:26 PM
Do it off a curb or small stair set and stay committed and you’ll get it
Testimony and apologies
instagram
old edit
