Hub guard suggestions?
6/22/2014 4:48 AM
I've been getting into grinds and I'm starting to notice a little wear on my spokes so I figured i should get hub guards pretty soon. I have an eastern trail digger with " REAR HUB Fully Sealed 36 hole cassette hub, Forged
Alloy Shell, 1pc. 9-tooth chromoly driver, 14mm
chromoly axle, 5 sealed bearings.
 " and the front is "36 hole Alloy Shell,
3/8” Chromoly axle
". I was looking through Danscomp and just saw some "one size fits most" hub guards. My rear hub-guard would be going on the driver side
6/22/2014 6:21 AM
Drive side guard I'd get an s&m cymbol
The other tree sides just get gsport glands they are the best guard I've used
6/22/2014 7:24 AM
Eastern has the pop n loc setup for their hubs for non drive rear.
Get a chromoly drive side or plastic just for the flex.
Non drive is pretty open. Front, the gland would likely be a decent option.
6/22/2014 8:36 AM
Alright, and thanks
6/22/2014 8:37 AM
...more
Yea I have to check the gland hub guard , thanks
6/22/2014 10:30 AM
If its the spokes youre worried about, Gsport Gland. For hub protection, Eastern Pop-N-Lock is pretty sweet.
6/22/2014 12:27 PM
Get The Daily Grind Infinity & DSG, they aren't cheap, but they'll last an eternity!! For the Fronts, I agree with everyone else on this, get G-Sport Glands, they'll do whilst You have Your Stock Hub!
6/22/2014 12:55 PM
Topsey wrote:
Get The Daily Grind Infinity & DSG, they aren't cheap, but they'll last an eternity!! For the Fronts, I agree with ...more
Nice, I give them a look once I'm at a computer. I just bent my sprocket trying to feeble a wooden park bench. Do you think I should try and bend it back into shape?
6/22/2014 2:49 PM
You can yes, but once it's gone it'll be hard to get it A. Perfectly straight again & B. It won't stay straight for long!
You're gunna want to get Yourself a new Sprocket, You should look into THICK Sprockets, 8mm+ thick or even a Bash Guard Sprocket, Subrosa Magnum, Fit Key Guard, The Daily Grind Millennium, Odyssey MDS, Sunday Knox, Or even a Shadow Disaster Guard.
Good Luck!
