The Cinema VX2 cassette hub features a CNC machined 6061 aluminum hub shell with 2 precision sealed bearings, a 14mm hollow heat-treated chromoly axle, alloy axle nuts and a 1-pc chromoly driver with 4 pawl engagement system and ceramic driver bushing for greater reliability. The driver features a new Switch Drive System (SDS) that allows the pawls, springs and ring gear to be flipped between RHD or LHD.
OE Replacement Parts
Axle: 14mm Hollow Chromoly
Driver: 1-pc Chromoly w/ "Switch Drive System"
Driver Bearings: Polymer Bushing
Driver Pawls: 4 Pawls (Reversible)
Driver Spring: 4 Individual (Reversible)
Hardware: Aluminum
Hub Shell Bearings: 6902 (x2), Verify bearing number on side of rubber seal
Weight: 16.2 oz
Odyssey Antigram FA Cassette Hub
The Odyssey Antigram FA cassette hub features a lightweight 2014 aluminum hub shell with canted flanges for increased spoke support, a 17mm hollow chromoly center axle, 14x1.25mm chromoly axle bolts for maximum strength, precision sealed bearings, 1-pc chromoly driver with sealed needle bearings for reliability and a reversible 3 pawl engagement system for RHD/LHD use.
14mm OE Replacement Parts
Center Axle: 17mm Chromoly
Axle Bolts: 14x1.25mm
Driver Bearings: Sealed Needle Bearings
Driver Pawls: 3 Pawl Reversible
Driver Spring: 3 Individual (Reversible)
Hardware: Alloy non-drive cone
Hub Shell Bearings: 6903 (x2), Verify bearing number on side of rubber seal
Weight: 14.6 oz
