I need 2 trick tips.
10/5/2011 4:44 PM
Edited Date/Time: 10/5/2011 4:54 PM
First, on halfpipes i have a bad habit of caseing, im pretty much fine on QP's. I get a good amount of air too which makes it worse, so just wondering how do you guys not case? I do like people say and pull up before my front wheel hits the coping but i still do :/ Its really bad timing cause im learning turndowns and lookback :p
Second, need some help on tailwhips and 180 whips, im closer to 180 whips but i just cant get my feet on the pedals, i always land with both feet on one side even though the bike spins enough. IDK if i just need to bring my feet in more or if theres something else i need to do. thanks ^_^
Turn Around & Take It Like a Champ.
Badass Rap Songs
I has multiple refs.
10/5/2011 4:53 PM
pull back into the ramp a little more man
Trails not Rails
E21 - Resto + E30 340i M60 v8 build + E36 328ti Daily skidder
10/5/2011 5:28 PM
sounds like your not pumpimg all the way through the quarterpipe i had the same problem about the same time you did when you pump all the way through turndowns and lookbacks will just click in to place because your legs are already straight.
10/5/2011 5:58 PM
10/5/2011 6:34 PM
Warchol2 wrote:
thats the video i watched to learn to air out in the first place T.T
Badass Rap Songs
10/5/2011 8:00 PM
for whips:
if your doing them on a QP or a bank, try and hop away from what your doing it on and land farther down the ramp at first. this will give you more time to whip it around before you land. also, make sure when you whip your doing small arm circles and when your in the air try and suck both legs up until your bike gets under you, then put the feet on! Take it one step at a time tho... Try and get both feet in the right sides, then try and get front foot on the pedal, then put both on. you got it mang!
10/5/2011 8:06 PM
You're supposed to let your front tire bounce off the coping...
10/6/2011 5:07 AM
SoCalShreds wrote:
for whips:
thank you sir!
Badass Rap Songs
10/6/2011 11:38 PM
i need to get a bottom bracket...ur getting too good!
10/7/2011 4:41 AM
this video actually helped me big time, i was doing stuff wrong and i didint even know it
Brennan Huff: "I'm so scared right now. I'm just gonna to do what's sensible, I'm gonna file for unemployment. Then I'm gonna try to get a job at Enterprise Rent-A-Car, because they got an excellent corporate structure and they... *they* give *you* the tools to be your own boss."
10/9/2011 8:08 AM
actually you are not supposed to do that, you lift your front a bit and then lift off when your back wheel hits.
Subscribe to me on Youtube.
10/9/2011 7:33 PM
erm, not to sound like a douche, but you should probably learn how to air out etc before you go trying whips!
10/9/2011 10:09 PM
Edited Date/Time: 10/9/2011 10:10 PM
it helps to let both wheels bounce off the coping...
10/9/2011 10:11 PM
this.
usually letting the tire bounce off the coping makes the perfect amount of pop for me
Bike check?
10/10/2011 4:43 AM
I can air out, but its like when i try to ride a HP i go up and air out once, then when im airing out of the other side I case. Its stupid.
Badass Rap Songs
10/11/2011 3:12 AM
youre not closer to landing 180 whips then you are whips spinning just gives you more momentum so the bike comes around more..... the absolute hardest part is finding your pedals first you have to wait for the bike to come around for me at about 270 i start to drop my front foot down and move it towards my pedald and as soon as my front foot catches the pedal i pull my back foot down and into the pedal
