I'm about to go crazy and break my chain (help)
3/22/2013 4:08 AM
Ok this is pissing me off so much.
My chain stays loose No matter how much I pull back my rear wheel and tighten up the nuts.
If I finally do get it tight, when I move the pedals forward half way it becomes loose (the chains sometimes actually touch the chainstays), then if I move the pedals forward again half way it becomes tight, then I move the pedals half way forward again and it's loose (and so on).
Any help please!
3/22/2013 4:16 AM
3/22/2013 4:19 AM
Maybe it's because you are not keeping the wheel straight into the dropouts, try to get it as straight as possible and then tighten evenly.
3/22/2013 4:51 AM
Bent sprocket. although i doubt your capable of that.
Latest edit (Check it out) | Anything With Two Wheels Goes!!
"Fuck it and Huck it" -Tomdon
3/22/2013 5:04 AM
This, aha. Hopping won't do it but just make sure its not bent. I rode a bent sprocket for like 3 months and it was terrible. It ruined my chain, and it would get really tight and then super loose.
Phone - 704 - 797 - 6844
3/22/2013 5:21 AM
Here is the problem. I made a vid
And the sprocket is def not bent.
3/22/2013 5:27 AM
that has to be the sprocket , because ive had the same problem ... maybe its not bent but its for sure not a circle
3/22/2013 5:31 AM
This. You need a new sprocket same thing happened to me.lol
3/22/2013 5:44 AM
Yo sprock is warped, bruh.
3/22/2013 5:46 AM
Your sprocket is definitely bent
3/22/2013 5:46 AM
Try my link. It's either your sprocket is bent or something (which I doubt) or your wheel isn't on the dropouts straight (most likely). The link above would fix that problem.
3/22/2013 5:56 AM
Yep your sprocket mate you have bent it now you need a new one smile
3/22/2013 6:16 AM
Here is the sprocket.
Looks ok..
3/22/2013 6:19 AM
Edited Date/Time: 3/22/2013 6:19 AM
it looks fine , maybe when you put it on the spindle , you forgot the adapter ?
(not familiar with that sprocket so idk if it needs an adapter or not)
3/22/2013 6:22 AM
Id just go ahead and buy a new sprocket honestly
Text For Faster Response (727) 218 4305
Follow Me On Instagram - @Marcog_727
Refs–
Sold : Mrhavoc1988, Skubasteve, Joe_Martinez, -Havok-
Bought : ii Krxfted, Tomdon, SnM An1mal, ScramHype, Ecuadevil, TheHorrorContract
Traded : Wolfen, Kevin_Burnett, The_Bmxist, Wilberto_Mora, Mobking, Joe_Martinez
3/22/2013 6:25 AM
Put your sprocket on a smooth, flat surface, like the kitchen table, with nothing under it. Tap on it all the way around. If it rocks at any point, it's bent.
3/22/2013 6:27 AM
Edited Date/Time: 3/22/2013 6:27 AM
oh he wouldnt have forgotten it. Remember---he is a pro bike mechanic and over examines EVERYTHING. guaranteed he did forget anything. NEVER!
Refs:
Traded: tomdon
n-dür on facebook
3/22/2013 6:30 AM
sunny i saw the video. you have tight spots. you can tighten it on the loose part. but that would be bad for your chain because your tightspots are so bad. Like I commented on the video. get an odyssey million dollar. it lasts forever
Old bike VVV
California Living
3/22/2013 6:53 AM
So what's causing these tight spots?
3/22/2013 6:53 AM
Seems fine
3/22/2013 6:58 AM
sproket is bent our ovalized
pcoco ticaleb
3/22/2013 7:41 AM
If you grind and smash your chain/sprocket you will get tight spots. I tacoed 2 sprockets before i got my million dollar. It lasts foreva!!!!
Old bike VVV
California Living
3/22/2013 7:45 AM
my two cents
i think your putting the sprocket on crooked. put your sprocket on the spindle tighten the cranks then put the sprocket bolt through the sprocket into the crank.
3/22/2013 7:48 AM
Is your spindle adapter on?
Refs–
3/22/2013 7:52 AM
Spindle adapter?
3/22/2013 7:53 AM
if i remember correctly the kink completes don't need a sprocket adapter but its been awhile since i've had one for repair at the shop.
3/22/2013 7:54 AM
sunny.jomofo wrote:
Spindle adapter?
when you first took off your sprocket was their a washer/adapter that sat between the sprocket and spindle?
3/22/2013 7:56 AM
sunny.jomofo wrote:
Spindle adapter?
Yeah, for a 19mm or a 22mm spindle, goes in the hole of the sprocket
Refs–
3/22/2013 7:57 AM
Edited Date/Time: 3/22/2013 7:58 AM
Well this us what I got on in order before the crank.
Anything in the wrong place?
3/22/2013 8:03 AM
I think your sprocket should go on that ring that's closest in. That looks like its your sprocket adapter
509-301-202one. April 14 Bike check
Refs-ninjacat33 x2, Warchol2, A08 x2, fsearles, bmxscout48, blackmammoth, ilovemybike22, ecuadevil, bmx, J.r._Faw, Pavimo, kymike, ScramHype, xlilkillaluc15x, bmxnick2511, semobmx, robinson79 x2
eBay - 120+ transactions, 100% feedback
