To ride a gyro if I don't have the gyro tab holes?
u can run a gyro plate
"The ratio of hours of building and maintaining trails is astronomically skewed in the wrong direction, but the pay off is indescribably worth it."
Anthony! wrote:
Do you have one you would recommend?
Idk any brands that make em but im sure you can search around the internet to find what you need. Ive seen a couple people run them before. it just goes around the fork tube under the stem where you put the spacers.
what kind of frame do you have, because you're not getting a gyro plate to work with an integrated headset....
titties and beer > everything
this or drill them
MY SEXY BIKE CHECK!
sunny.jomofo, even more of a bitch than Dane wild!
if you need to talk to me text me 1-734-301-6545
on the legit list
35+ clean refs
o reallyy?
shadow conspiracy gyro plate.
never drill holes colton, your an idiot if you drill holes.
yeah you can't get one to work unless you have a bike shop drill the frame for tabs, it's been done plenty of times, the shop by me drills for tabs a lot and it doesn't substantially weaken the frame...
Brokenbmx wrote:
o reallyy?
exactly how does that work to hold the cable stationary on the frame?!
Nike iD wrote:
Drill them?
abreezy111 wrote:
def not unless you want to substantially weaken your frame and cause problems for yourself
A upper plate will work. But you need to tap your head tube for the lower part. It will not weaken your frame, if it did why would so may frames come with them? Just take it to your LBS and ask them to do it for you.
Refs: SolomonGrundy!
Angrypenguin.biz
Braswellrealty.com
I have a codec and dont run a gyro. Just tryin to help the dude out.
The above posted gyro plate I see no reason why you can not run it with an integrated head set
we're all trying to help him out, there's three pieces to the gyro (the upper plate or stem with tabs, the detangler that spins, and the lower mounting plate or frame gyro tabs) the gyro plate above is for the upper cables to mount to, you won't get a lower gyro plate onto the frame and the lower cables will not mount to the bike so without tabs it's not going to work. i used to run a gyro before...
Standard headtube gyro.
Note lower plate.This will not fit a int.headset.You need tabs on the frame.
Old,stupid,and funny.
now I learned something for the day haha. good to know for future reference.
Drilling holes in the frame just seems super sketch to me personally. It'll be cool to see if that new "single cable" gryo design ever catches on
haha a single cable thing would be cool...i don't think he should drill the head tube on his own, i'd have someone at a bike shop work on it.
There was a prototype of a single cable gyro at interbike this year but I cant find it online again
i seem to remember whenever int. headsets came about, somebody offered a lower plate that fit. just dont remember who it was. all my buddies just dremeled the inside out so it would fit, though
Maintenance guy at The Railyard Bike Park in Rogers, Arkansas
facebook.com/TheRailyardAR/
Insta @the_railyard
facebook.com/tedhuie
Insta @ted_danger
or get some tabs, shave off the little nub, and have them welded on
Insta @the_railyard
Insta @ted_danger
I remember when i had one of these.
The only way I have ever heard of a gyro working with an integrated headset without gyro tabs was with an Odyssey gtx-r and there was some random lower plate I once heard was used.
But I think it was one of those situations like the DK 12t freewheel. They made it and it just didn;t work properly so it went away
http://bmx.transworld.net/1000137499/news/new-detangler-system-from-affix/
yup thats it!
I think its a pretty cool idea that could catch on
