Just wondering...
5/29/2014 1:43 PM
For 36h wheels, which is stronger, 3x or 4x lacing pattern? And can you lace a 36h ribcage 4x?
IG
@curtis_cantbmxwell
5/29/2014 2:02 PM
'Here are primarily five different lace patterns, which are radial, 1cross, 2cross, 3cross and 4cross. Generally on a 36 hole wheel 3cross is strongest and on a 48 hole wheel 4 cross is strongest. If you wanted to save some weight you could run a less number cross pattern like a 1cross or 2cross. Some wheels are even built with a radial lace also known as a 0cross. The most common application for a radial lace wheel is a front race wheel where the rider is either very light or very smooth. The reason a 1cross or radial wheel weighs less than a 3cross or 4cross wheel is the spoke length. For instance, if a 48 hole wheel laced 4cross has a 185mm spoke length then that same wheel would use 172mm spoke length if it were laced radial. That is a difference of 13mm per spoke, which is equivalent to removing 3.4 185mm spokes. '
5/29/2014 2:13 PM
Yeah he pretty much summed it up there mate
