Let's talk tires!
7/13/2013 10:35 PM
I wear out tires fast. I dont really do sliders or anything like that, i ride a ton! I spend every minute possible riding, so my tires go quickly. I know rubber compounds can be hard or soft. And that some tires are thicker than others. My question is: what is the hardest/ longest lasting rubber used in a tire? Which tire has it? I had a Glh and it lasted maybe3-4 months. Which is the longest a tire has lasted for me. Basically all im asking is what rubber is best in a tire? And does anyone know anything about tire manufacturing and rubber compounds??
7/13/2013 10:48 PM
Odyssey Aitken. Been on mine for over two years now and still have plenty of life left.
7/13/2013 10:50 PM
I'd also like to know, all the Tyres I seem to get always last exactly 6 months except for the Dirt Monster I currently have up front.
7/13/2013 10:55 PM
I have one on the Back right now, had it 6 Months, at it does look a little worn, but it looks fine. However in the last 6 days I have got no less than 8 completely unrelated surface punctures.
7/13/2013 10:58 PM
BMX_Forever wrote:
I have one on the Back right now, had it 6 Months, at it does look a little worn, but it looks fine. However in the last 6 ...more
I haven't had one flat or puncture on my Aitken. Although I'm gonna be replacing it soon because the tread is too shallow for dirt and stuff now.
7/13/2013 11:05 PM
Xxohioanxx wrote:
I haven't had one flat or puncture on my Aitken. Although I'm gonna be replacing it soon because the tread is too shallow for ...more
Well I didn't get a single one for 5 Months and I'm known to get punctures but now I get them pretty much every session.
7/13/2013 11:19 PM
I burn out aitkens way too fast for it to be funny. i burnt one out in a month (Plyte). sucks. not hard enough rubber or something.
7/14/2013 12:10 AM
are odyssey aitken good for street and park?
7/14/2013 12:23 AM
Odyssey aitken street are the best tire I've ever run
7/14/2013 12:24 AM
Although i do wear tires remarkably fast, these are great for street, park, and dirt. there is no tire that grips as good as this one that also rolls super quick! It is great for it!
7/14/2013 12:44 AM
MaximusBikes wrote:
Although i do wear tires remarkably fast, these are great for street, park, and dirt. there is no tire that grips as good as ...more
i run 2 fit fafs right now. i mostly ride street and a little park do you think i should just switch both of my tires out for aitkens?
7/14/2013 12:55 AM
CptnNick wrote:
i run 2 fit fafs right now. i mostly ride street and a little park do you think i should just switch both of my tires out for ...more
Yes. I see so many bald FAFs its not even funny, definitely get aitkens. Get a 2.25 plytes! They are nice! But i think that an Animal GLH for the rear in 2.1 is great, holds up to anything you can throw at in and a 2.25 Aitken in the front would be perfect.
7/14/2013 1:43 AM
aitkens are great im running klytes front and back and they have lasted a year now and still going strong and i ride every day street and park and only every got one flat and run them over there max psi
ride or die
7/14/2013 1:48 AM
blackrose wrote:
aitkens are great im running klytes front and back and they have lasted a year now and still going strong and i ride every day ...more
What's the difference between k-lytes, p-lytes, and the regular aitkens?
7/14/2013 1:56 AM
K-Lytes are Kevlar bead, and I think P-Lytes have a special rubber compound, but I think the K-Lytes use the same compound.
7/14/2013 1:56 AM
Edited Date/Time: 7/14/2013 1:59 AM
klytes are folding tires and plytes are not and i think klyte have a higher psi and klyte are lighter then plyte but im not sure
ride or die
7/14/2013 1:57 AM
Plytes actually just have a thinner casing from what i can tell.
7/14/2013 2:01 AM
and klytes cost more plytes
ride or die
7/14/2013 2:03 AM
Just checked, it seems to be a casing using a different material, which is stronger, but it is a lot thinner so it is overall weaker.
7/14/2013 2:12 AM
heres what i found on odyssey about them
P-Lyte
P-Lyte tires upgrade the casing we use on our original tires with our unique, extremely durable and lightweight P-Lyte casing.
Available on the Hawk, Aitken, Ross, Path, Dirt Path and Frequency G tires
K-Lyte
Our K-Lyte tires combine all of our most advanced tire technologies into one tire. Having both our special durable and light weight P-Lyte casing and our ultra lightweight foldable bead.
Available on the Aitken, Ross, Path, Dirt Path and Frequency G tires.
ride or die
7/14/2013 2:18 AM
thanks guys I'm definitely going to look into getting some p-lytes probably soon or when I wear out my fafs
7/14/2013 2:26 AM
Do you guys know much about the odyssey path? I was thinking of putting a path in the back and the aitken in the front
7/14/2013 2:39 AM
That was one of my favorite combos, super grippy and pretty fast!
7/14/2013 2:45 AM
if you go with any ody tires you be good as gold
ride or die
7/14/2013 3:17 AM
Aitken street and a path in the arse end is a great combo
7/14/2013 7:36 AM
Get the new eclat ridgestone tires I think thats what their called their suppper thick
Bang Bang bmx
7/14/2013 10:26 AM
BMX_Forever wrote:
I'd also like to know, all the Tyres I seem to get always last exactly 6 months except for the Dirt Monster I currently have ...more
i run that in the front too never flats or wears down
