Little warning
3/1/2018 6:12 PM
When buying a freecoaster try to get one with a bushing instead of a driver bearing. My freecoaster driver bearing recently blew up on my 200th peg chink. I had it for 5 months ermm
It was a rant moonwalker freecoaster that came with my bike. Now i gotsta relearn fakies since i learned them on coaster. So just watch the specs before you pick up a coaster.
Ride for yourself and have fun
3/1/2018 6:40 PM
That's because it was a cheap stock freecoaster.
3/1/2018 6:41 PM
I don’t believe you
3/1/2018 6:43 PM
eskimojay wrote:
I don’t believe you
Believe me
3/1/2018 7:07 PM
*cough*Odyssey Clutch V2*cough*
grinsillytongue
3/1/2018 7:18 PM
Z coaster.
3/1/2018 7:22 PM
Z coaster for 285 dollars at transition bmx online store
3/1/2018 9:41 PM
Bushing coasters are the worst and of course your cheap freecoaster blew up after 5 months of learning on it.
3/1/2018 9:45 PM
Biggest waste of money ever
3/1/2018 9:53 PM
...and yet, so worth it!
3/2/2018 4:23 AM
What's wrong with bushing coasters?
3/2/2018 5:28 AM
Did you maintain it?
Ya gotta realize that peg bonks/chinks/whatever you wanna call them put a HUGE amount of stress on an axle/hub/bearings for a split second. You have your weight, your bike's weight, PLUS the force and speed of you coming down hitting on a tiny little area.
Side note, I have had coasters with driver bearings last YEARS with minimal issues.
3/2/2018 7:42 AM
Ya gotta realize that peg bonks/chinks/whatever you wanna call them put a HUGE amount of stress on an ...more
I couldn't maintain it because the driver wouldn't the driver wouldn't screw off. I tried to tap out the axle but i started hitting harder and harder and didn't want to break something. So i said fuck it and let it kill itself. Also how does greasing the drag bearings and clutch prevent the driver from blowing out?
3/2/2018 7:47 AM
Anthony Loves Subrosa wrote:
I couldn't maintain it because the driver wouldn't the driver wouldn't screw off. I tried to tap out the axle but i started ...more
You would be able to inspect it and prevent things from getting worse-instead of blowing a bearing you could find it a little haggard and replace it.
Also fresh grease and cleaning the dirt/grit out will make it last longer. That fine dirt/dust getting in there will act as sandpaper and grind stuff out causing it to blow out.
3/2/2018 8:50 AM
Had a demolition rotator last me 3 years without opening it up once , it worked awesome until it exploded , then I just got a new wheel 3 Years is long enough for a hub for me to ride until I buy a new one anyways
3/2/2018 9:18 AM
THIS....
ANY part will break in due time but if you invest in better quality parts they do tend to last longer.....
| (• ◡•)| (❍ᴥ❍ʋ)
3/2/2018 10:51 AM
Edited Date/Time: 3/2/2018 10:51 AM
bmxer_yoshi wrote:
THIS....
You buy cheap, you buy twice.
3/2/2018 2:19 PM
Driver bearings in any hub are always the first to go. I've never seen a hub that is different. I replace my driver bearing in my shadow raptor coaster at least twice a year. They're tiny bearings unlike the rest of the bearings used in the hub. The bearings are like 10 shipped so 20 a year isn't bad...thats less than I spend on bb bearings
