MDS on the inside question.
4/29/2014 4:28 PM
Sup Vital bums,
I have had 3 different frames. T1 2010 Barcode, T1 SFA, and my current frame, S&M BTM. I am a pegless LHD rider, who grinds both pedals. I want to run the MDS on the Inside but it hits my backend. Which it has for all three frames I listed. My MDS is 30 tooth but I have seen 30s ridden on the inside. Adding spacers so it fits makes my chain alignment bananas! Is that what pros do?! Any have any ideas, I imagine a 28 and 25 will face the same exact problem.
Also, I scooped the new Stranger seat, pics on my instagram.
Shoot some shit at me, I might go buy a 28th tomorrow.
4/29/2014 4:57 PM
Edited Date/Time: 4/29/2014 4:58 PM
Pics of the mds issue? My guess is that you could probably get a 25t in there and maybe a 28t... depends on how tight it is. my 28 fits in backwards fine but i also have longer chainstays.
4/29/2014 6:27 PM
My 28's teeth almost touch on my United Dinero, otherwise id run it backwards. Try a 27? Its still a highish gear ratio. Or get a 25 which almost HAS to work and get an 8t Èclat hub or wait for the Primo Remix v2. Or buy an 8t blackout driver if you have a Joytech hub. Or 8t Primo Mix driver if you have a Cult Match/Primo Mix/Remix.
4/29/2014 7:20 PM
HardBMX_Tim wrote:
My 28's teeth almost touch on my United Dinero, otherwise id run it backwards. Try a 27? Its still a highish gear ratio. Or ...more
I got a Cult Coaster and I will throw a pick up in a second
4/29/2014 10:22 PM
Edited Date/Time: 4/29/2014 10:23 PM
Only thing I hate about guard sprockets is that you have to put the chain on from behind the sprocket. At first, I kept trying countless times to force the chain over from outside of the sprocket and I kept thinking the built in guard was too huge, but it appears I was just not noticing things carefully. But anyways, I use the standard small and big cone/dust cover provided with almost all BB kits. I run just the small dust cover cone alone on the drive side, and the big cone on the non-drive side along with like one medium sized spacer. Fits just fine on my frame with the MDS in 25t.
4/30/2014 4:37 AM
Find a frame with a wishbone. Looks like the bonedeth cult 45 has clearance and the wishbone Sundays
4/30/2014 6:31 AM
Dont know.... But really nice seat man!
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
4/30/2014 6:46 AM
Why do people ride the MDS backwards ????
Text Me For Faster Response (770)572-6425
Refs]: AllDayErrday.JakeSalbert.FunkyChicken.SuperstarDK.Genesis.ilovemybike22.blainep80.
Tommyboy.1of1547.oscar5788.Wade.Droogskull.TCbmx.Showtime402.nettyrspeghetti.theprophet.Kurtnut.
aw1234512.ScramHype.KnightLight.Tito24.Obiwanchromoly.Spikez5.BEASTASSDICK.Tjthemaxx.Areanfsl.
_brendan.Penman166.J.r Faw.SK1611.DontDELETEmePLEASEandTHANKyou.nshs2010.martinnn1004.
Warchol2.milou.Shutta.asilva23.a08.faiilz.HowlerFbm."FLORIDABMX"Dogbones.The Balt.Bdk1313.Jeez123.
Broughton.vin93.ticaleb.Hooligan703.dream.Element4all.skubasteve.Kymike.Andynahnah.Killawolf.Bmx-junkie.T-1 517.BmxKitten.Jaekass.Mario.villegas90++++++++++MANY MANY MORE
4/30/2014 9:07 AM
If you have your sprocket on the opposite side to your normal grinding side, then a backwards MDS protects your chain for Crookeds and Crankslides.
4/30/2014 4:14 PM
What BMX-Forever said. Like for instance, I grind right side and run a LHD drive train. I dont grind on the left whatsoever (yet) so I want the guard for when I try my crank arms, the inner guard helps alot more for this purpose and since I dont grind on that side I dont really need the outer guard, so flipping the sprocket is easier/lighter/cheaper than buying the inner guard.
However I cant flip it on the dinero so im SOL haha. I rarely try crank arms anyhow.
4/30/2014 4:45 PM
Edited Date/Time: 4/30/2014 4:49 PM
Slapped a 25th on, check this chain alignment! HAHAH it works that is all that matters
