MacNeil Swagger Non-Drive Side Hub Guard?
9/19/2013 11:16 AM
Does anybody know of a hub guard that will work with the MacNeil Swagger hub (not the G-Sport GLAND, I am already using that)? I already e-mailed MacNeil and am awaiting there response.
The GLAND works great, but if I grind a perfectly square edged ledge the zip ties will usually snap off from impact. Rounded off rails or edges are not a problem.
This is my exact hub, mine is LHD.
Thanks,
Grizz
9/19/2013 11:17 AM
thats a bad ass lookin hub
9/19/2013 11:25 AM
Thanks, I hand crafted it myself.
9/19/2013 11:34 AM
Should've used rhinocerous skin...
Wouldn't need a guard then.
Tried DG's yet?
9/19/2013 11:41 AM
? yeh?
9/19/2013 11:43 AM
universal aluminium hub guards all the way
don't overthink it just do it !
9/19/2013 12:06 PM
Animal PYN should work. It comes with different sized spacers so its universal to most hubs.
9/19/2013 12:06 PM
9/19/2013 3:33 PM
BRANDON_90 wrote:
? yeh?
9/19/2013 3:34 PM
Example plssss. I might try to make one myself.
9/19/2013 3:34 PM
Thanks for the info!
9/19/2013 4:28 PM
Edited Date/Time: 9/19/2013 4:29 PM
Salt plus also makes one that replaces the existing cone nut with a thinner nut (aka drive side nut) and spacers to shim it to where it fits.
Others such as FBM universal should work but maybe snug in the frame. Im told the Demolition guard for the Rogue and Rolls cassettes fit as well but I have never bothered to try mine since I dont ride my swagger cassette much anymore.
You can also use the universal shadow guard which is thicker so it wont punch the center out like the thinner ones tend to. Just replace the cone nut with a drive side one from a similar hub (odyssey v3 or any joytech built cassette) and shim with shims or wheel nut washers if necessary.
Hope that helps give more options.
9/19/2013 5:13 PM
In all seriousness, use the shoelace.
The zipties snap easily. A buddy used the provided shoelace on his 1st iteration Gland, and it is STILL on without issue.
7/29/2014 12:08 AM
any one know where or what driver will work on this i need a 9t
7/29/2014 12:10 AM
probably a joytech clone just guessing
so probably the joytech driver from dans? might work idk if it will
7/29/2014 12:25 AM
this.
I'm fairly positive it's just a Joytech clone, so any driver that fits an Odyssey Hazard hub should fit it. The Odyssey or Blackout driver on Danscomp are good bets.
7/29/2014 12:32 AM
sundaybmxRR wrote:
this.
I'm fairly positive it's just a Joytech clone, so any driver that fits an Odyssey Hazard hub should fit it. The Odyssey ...more
well its a 4 paw is the blackout a 4 or 3? will that matter if its a 3 when it was a 4?
7/29/2014 12:34 AM
do you still have the original driver? pic of driver and internals would be nice
7/29/2014 12:35 AM
7/29/2014 12:36 AM
im getting this hub but its got a 11t and its good conditionand cheap and i need sealed really bad and i just want to know if i can get a 9 tooth driver for it
7/29/2014 12:39 AM
huntsforbunz wrote:
im getting this hub but its got a 11t and its good conditionand cheap and i need sealed really bad and i just want to know if ...more
wait is it unsealed?
just get a 30t and you will get less chain wear and the same as a 25/9t setup
http://www.danscomp.com/products-PARTS/458228/Sunday_Sabretooth_Sprocket.html 30$
7/29/2014 12:41 AM
Blackout driver is 4 pawl I'm pretty sure
7/29/2014 12:41 AM
no the wheel i have is unsealed i want this macneil hub and i love 25/9 so i need a driver that works for it
7/29/2014 10:05 AM
30-11 feels the exact same
7/29/2014 12:37 PM
but its a long story my cranks dont come off easy and i dont have any more chain so id have to buy a new chain, sprocket and fight my cranks thats about $55 while the 9t is $45 ill buy the driver and make this 100% easier
