Madera Mast stem bolt head sizes
11/26/2014 3:53 PM
Edited Date/Time: 11/26/2014 3:54 PM
I'm getting a Madera Mast stem, and I'd like to order some Shadow Hollow bolts with it, but I don't know which head size to get for the bolts, because the Shadow bolts comes in two options, normal and large, and the specs for the stem don't specify the stock bolt head sizes.
Here are the bolts Shadow Hollow Bolts
And here is the Madera Mast stem Madera Mast stem
Also, if you've tried the stem, did you like it?
Thanks!
11/26/2014 3:54 PM
Shadow bolts won't work with Profile or Madera stems. Also, hollow stem bolts are probably the worst things you can get. They can literally kill you.
11/26/2014 4:03 PM
Xxohioanxx wrote:
Shadow bolts won't work with Profile or Madera stems. Also, hollow stem bolts are probably the worst things you can get. They ...more
It says in the bolt description that they fit most stems from all companies. Are you saying that Profile and its sister Madera specifically don't work?
And are you being sarcastic about the who kill-death-murder thing?
11/26/2014 4:06 PM
Won't fit, different thread count.
Also, why get new bolts right away? To save a very miniscule amount of weight?
11/26/2014 4:15 PM
Edited Date/Time: 11/26/2014 4:16 PM
GorillaKing37 wrote:
It says in the bolt description that they fit most stems from all companies. Are you saying that Profile and its sister Madera ...more
No, they can literally kill you
If you order hollow bolts to save .25oz you are stupid, sir.
Instagram
11/26/2014 4:16 PM
Profile, Madera, and a few other American stems use different threads. They won't work.
And no, I read about a guy that was running hollow stem bolts and they snapped and he ended up dying. Hollow bolts are very, very weak compared to solid bolts, and you lose almost no weight. If you want to save that small amount of weight, go with titanium bolts. Still strong enough, plus they won't rust.
11/26/2014 4:22 PM
And no, I read about a guy that was ...more
That'd be like saying riding a certain thickness of tube can kill you because it may pop.
11/26/2014 4:23 PM
In all honesty I just wanted the color.
11/26/2014 4:24 PM
I just wanted purple bolts and since the hollow were only a buck more than the solid I figured why not.
11/26/2014 4:30 PM
FUCKING EXACTLY. Why would you ride a frame with .035" tubing all around? It can fucking kill you, it's not safe to ride. You're spending more money on less strength and less function.
11/26/2014 4:40 PM
Xxohioanxx wrote:
FUCKING EXACTLY. Why would you ride a frame with .035" tubing all around? It can fucking kill you, it's not safe to ride. ...more
I had the Danscomp Heavy Duty tubes in both of my wheels for a while and they both ended up popping and YES I had rim strips in. Dans Heavy Duty Tube
11/26/2014 4:42 PM
Edited Date/Time: 11/26/2014 4:42 PM
I had the Danscomp Heavy Duty tubes in both of my wheels for a while and they both ended up popping and YES I had rim strips ...more
That's completely fucking irrelevant and I thought you were saying tubes as in frame tubing. Seriously, go ahead, buy the hollow stem bolts that won't fit your stem, but don't cry here when they don't fit or when they break on you.
11/26/2014 4:42 PM
Oh you meant FRAME tubing. No I meant inner tubes... If I had meant frame tubing, why would I have said "pop"...
11/26/2014 4:43 PM
Because people on Vital are fucking idiots.
11/26/2014 4:52 PM
To be fair, I've jumped off at least 2 roofs & did more than just a few 360s down high drops, and never had an issue with breaking a bolt in my stem that had hollow bolts. In fact, I cracked the stem & never cracked/snapped a bolt.
They came hollow, I didn't buy hollow weight weenie bolts. My stem now has solid bolts though.
You're better off buying some spray paint.
11/26/2014 5:08 PM
sundaybmxRR wrote:
To be fair, I've jumped off at least 2 roofs & did more than just a few 360s down high drops, and never had an issue with ...more
Fair enough. Snag some bottles on Black Friday.
11/26/2014 5:09 PM
I'm not an idiot though. I think that guy just had some bad luck.
11/27/2014 9:17 AM
Xxohioanxx wrote:
That's completely fucking irrelevant and I thought you were saying tubes as in frame tubing. Seriously, go ahead, buy the ...more
Some of the most intelligent things ive seen you say yet
Idk how you guys ride but sometimes i do manuals going down hills going up to 35 miles per hour if my top tube pops im definitely going to die
Testimony and apologies
instagram
old edit
11/27/2014 10:14 AM
He's just trolling you dude.
IG
@curtis_cantbmxwell
