Messed Up Hub
12/28/2011 7:31 PM
When i pedal my bike its fine but if the back wheel is rolling and i am not pedaling, then my bike makes a terrible popping sound and it vibrates the whole drive system. I just got my bike a couple weeks ago. Whats wrong with my bike and how do I fix it.
I just wanna ride some BMX and make music
12/28/2011 7:42 PM
uh, kinda sounds like your bearings are messed up,
email: nctesio@gmail.com
EPIC bikecheck!
FOLLOW ME @nathanxflex
Imagine there's no heaven, It's easy if you try. No hell below us, Above us only sky - John Lennon
&party and bullshit
&party and bullshit
&party and bullshit
12/28/2011 7:55 PM
try loosening your hub. that happened to my old hub also
i ride a Sunday
Refs: irideafly, subrosarider65, ridebmx456, ayobmx, spikez5
cell #: 424-219-2490
12/28/2011 8:21 PM
heres what it sounds like if that helps
12/28/2011 8:23 PM
omg that sound horrible kinda like a bunch of nuts and bolts in a blender
12/28/2011 8:49 PM
yeah it makes me cringe
12/28/2011 9:22 PM
My first guess is that a pawl or multiple pawls have grit under them or are misaligned and don't get compressed far enough into the driver, causing the engagement ring to have to force itself over the top of the pawls while freewheeling. Normally the engagement ring would just skip over the top of the pawls lightly, making the normal ratcheting sound. In this case, I suspect that something is underneath the pawls making it much more difficult to compress the pawls in a freewheeling scenario.
Could also be your bearings...Simple way to tell is to remove the wheel and spin the axle without touching the driver; if it spins smoothly, then your bearings are probably fine. If it's really difficult to spin, then your bearings could be at fault...are these sealed or unsealed bearings?
12/28/2011 9:41 PM
im all confused about pawls and engagement rings. im not getting married lol. but seriously what are they
12/28/2011 9:53 PM
This is much easier to explain in person with a hub to demonstrate. I will do my best. I may make a video sometime.
Okay so this is what a normal cassette hub looks like inside with the driver removed. The notches you see form the "engagement ring." It is called an engagement ring because the pawls "engage" into the flat sides of the notches when you are pedaling. When you are freewheeling, the pawls skip over the angled sides of the notches.
Here is a normal BMX driver. See the sharp edge of each of the pawls? That sharp edge is what catches the flat edge of the engagement ring notches when you're pedaling. When you stop pedaling, the flat tops of the spring-loaded pawl hit the angled sides of the notched engagement ring and push the pawl down. This makes the ratcheting sound we all know and love...
Here is a driver with the pawls removed, just so we're clear on what a pawl is:
I'm really sorry that I can't explain it any better. If I was face to face with you and had a hub to show you, you'd understand it in 20 seconds.
12/29/2011 8:35 AM
its alright i understand it now.
12/29/2011 4:40 PM
what is the differnce between sealed and unsealed?
i cant take the bolt off to remove my driver.
12/29/2011 5:27 PM
if it's unsealed you will see loads of tiny metals ball bearings inside the hub, if it's sealed then you will see bearings in a case. If you have ever seen a skateboard bearing they are sealed bearings
Sealed
un-sealed
