Metal pegs (and disasters)
8/9/2019 2:57 PM
Edited Date/Time: 8/9/2019 3:11 PM
Are hi-ten and aluminium pegs even worth it? I have never used pegs so I have no idea, but it seems like alu would crap out fast and hi-ten seems worthless, when chromoly exists. I'm looking for metal pegs so I just need some advice.
Or should I go with plastic? How long do plastic sleeves last, when you grind mainly on rails?
Also when I tried to do some disasters, I broke 3+ ball bearing in my headset. is the headset that crap or did I do the trick terribly? The headset is a Mission Sealed Integrated (41.8 x 45), the stock that came with my Kink Whip XL 2019.
8/9/2019 6:56 PM
Disasters are quite hard on the headset but that only tends to happen when the headset is run loose.
8/9/2019 11:40 PM
If you're going metal pegs with the intention of grinding, and doing a lot of it, chromoly all the way. If you're doing mainly stall tricks on quarters or not heavily using pegs, aluminum seems to be the park rider's choice.
Scooter kid trying to ride a bike. Instagram: @scootereyn // YouTube: RH MEDIA
8/10/2019 9:44 AM
Grinding on rails or even well waxed ledges with angle iron, the plastic lasts a good while, especially if you rotate every once in a while.
8/11/2019 7:40 PM
Park ride 75 percent of the time = plastics
Street ride 50 percent of the time = steel pegs
I recommend straight aluminum pegs 0 Percent of the time unless your a flat lander.
8/12/2019 2:56 PM
I'd only recommend steel pegs personally, I use the friction for certain tricks but that's just me.
As for disasters it does sound like the headset was a little loose to begin with, had integrated headsets since they were first introduced and they've been amazing. I don't miss hammering in cups.
8/12/2019 3:03 PM
I might go with chromoly pegs then.
But I'm pretty sure my headset wasn't loose.
8/12/2019 10:07 PM
Possibly just a faulty unit then, these things happen unfortunately, especially in the quantity that they are made.
8/13/2019 3:21 PM
My experience: I had an Odyssey pro headset (looked after, 3/4 months old) and managed to break about 10 balls until I could be bothered to replace it, all other headsets I've had (from all different brands and prices) have worked flawlessly.
Like the previous reply says, some untits are just a bit crap and that's just what happens. Replace it and you should be all good
8/13/2019 6:08 PM
Tensioning it properly will(usually) prevent that.
8/14/2019 9:29 AM
How tight should I go? I always go until it doesn't wiggle then a bit more to make sure it doesn't come loose. I don't go really really tight because alloy top caps are don't last long like that
