Mini race BMX riser advice
2/2/2014 3:10 AM
Hi everyone .
My 5 3/4 year old is racing a mini race bmx. The stock redline bars have a rise of 2.5 inches. Some people at the track tell me I should get riser bars because they advise he is leaning to far forward. If he is some what higher he can put more power into his pedal stroke . Can anyone advise what rise I should go for ? 3.5 inch or 4.5 inch ? I don't see 4 inch about anywhere. I know I will need to cut to suit . Any advice would be great .
regards
Kemble,
2/2/2014 3:18 AM
Coming from 2.5inch, a 4.5inch might be a big change. One inch might do the work, but i am only guessing, cause i know nothing about race bmx, and even less about small bmx race bikes lol.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
2/2/2014 7:59 AM
I also don't know much about racing or race bikes, but generally larger (and wider) bars give more bike control
-HardBMX_Tim
2/2/2014 8:02 AM
you could also adjust the angle of the bars to get the maximum hight. If not just move up by an inch or so.
Old bike VVV
California Living
2/2/2014 8:07 AM
I complety forgot about spacers, i guess you can buy some spacers and try different heights.
RIDE OR DIE
THE ROUTER
2/2/2014 9:25 AM
Try 3.5 and add/remove headset spacers to dial it in.
2/2/2014 10:12 AM
Edited Date/Time: 2/3/2014 1:53 AM
Not sure its an option I will check . Thanks everyone smile
2/3/2014 1:53 AM
I have checked the bike. There already is 2 spacers below the stem both approx 5mm each. On removing the cap on the top of the fork I have found the fork tube is approx 3 mm below the stem clamp top. So an extra spacer to rise up the stem not looking to be much of an option. I might squeeze in one spacer 4-5mm tops but the upper clamp on the stem would start to loose its grip.
2/3/2014 4:36 AM
Get 4.5 bars then and remove spacers and put them ontop of the stem if it feels too tall.
2/3/2014 7:43 AM
Id do that^
RIDE OR DIE
THE ROUTER
2/3/2014 7:57 AM
Edited Date/Time: 2/3/2014 8:04 AM
I have a son about the same age with the same bike.
If he is reaching too far forward get him a zero offset stem. That will bring the bars back towards him so he isn't reaching as much.
2/3/2014 8:03 AM
