My chain keeps loosening!!
2/1/2014 7:55 AM
Ok so my chain keeps coming loose within about an hour of tightening it. I have a primo dsg and pegs on. What should I do?
-If your not crashing... YOUR NOT RIDING!!
2/1/2014 7:58 AM
Thight the bolts of the rear hub more.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
2/1/2014 8:10 AM
Do you have the washers on the outside of the frame? If not, put them in between the frame and bolt. Probably not your answer but it's worth a look.
2/1/2014 8:15 AM
biggybuggy wrote:
Do you have the washers on the outside of the frame? If not, put them in between the frame and bolt. Probably not your answer ...more
this , sometimes the bolt wont grasp the frame and it will slide loose , but i find a spacer will help prevent that
2/1/2014 8:21 AM
if you grind and don't have the pegs with the non spin bolts? idk what they are called but they help.
