My cranks are stuck
1/7/2017 9:22 AM
I need help, my cranks a stuck an I've sprayed loads of wd40 in them but they won't budge, any ideas?
1/7/2017 9:50 AM
What type of cranks do you have? 8 or 12 or 16 spline? 2 piece or 3 piece? 48 spline? Post some pictures.
If you have a rubber mallet, here's my advice. Take the spindle bolt out, and lightly tap the crank from the opposite side, like this Photo
1/7/2017 9:51 AM
Edited Date/Time: 1/7/2017 9:52 AM
It doesn't matter if it's on your drive side or non drive side, I've done it with both. Don't be hesitant to give it a few hard whacks, just be careful.
1/7/2017 10:37 AM
They are 3 peice 48 spline I think, av tried tapping them but still nothing and both spindle bolts are out
1/7/2017 10:55 AM
Put the axle bolt half way in, and hit the bolt
1/7/2017 11:40 AM
Will try that's in the morning thanks
1/7/2017 12:29 PM
This and maybe spray a little Pb blaster in it and let it soak.
1/7/2017 12:31 PM
Sometimes you just have to beat the shit out of them
IG
@curtis_cantbmxwell
1/7/2017 12:36 PM
Exactly this. Rubber mallets are the best most useful tool for bike maintenance.
My Ride
My Other Ride
IG: evildeadhands
1/7/2017 12:38 PM
1/7/2017 12:39 PM
I already beat the shit outta it but still nothing
1/7/2017 1:03 PM
If you keep smacking the crap out of it it will come off. A good penetrating oil will help too. If you put the bolt in the crank arm just a couple threads and a screw driver or pry bar on the back of the crank arm and pry a little and smack the bolt it will come off.
1/7/2017 4:29 PM
What you can do is find a bolt the same thread/diameter as the spindle crank bolt itself, screw it in a couple of turns, grab a hammer and a piece of timber and smack it until it budges, the timber is to protect to the spindle bolt.
1/7/2017 4:35 PM
Do you have a crank installation tool? you can use that instead of the bolt to beat on.
Let it soak for a little longer and keep adding more WD40 then try it again.
I had a problem similar to this years ago with my Sputnic cranks. I actually ended up taking both bolts out and riding without them in for like 2 weeks and they stayed tight the whole time haha but after that they came off after beating the fuck out of them with a rubber mallet
1/7/2017 4:38 PM
Let it soak for a little longer and ...more
Holy shit...
1/7/2017 5:58 PM
Enough lube and brute force, anything is possible.
1/7/2017 6:06 PM
Seconded re PB Blaster.
It is more hardcore than WD40 etc, and is some nasty, jet-fuel smelling stuff that you don't want to use too often,
but soaking in that for a couple of days & it WILL work to get them off.
Frmrly BmxBos
1/8/2017 12:19 AM
That's what I keep telling the wife
1/8/2017 2:50 AM
Love it
1/8/2017 8:37 AM
I tried bashing the bolt in to the spindle and still nothing
1/8/2017 9:09 AM
Have you tried it from the other side?
1/8/2017 11:07 AM
Have you tried turning it off, then on again? Sorry.
1/8/2017 11:24 AM
Cheers for that
1/8/2017 11:25 AM
Yeah I've tried both sides, considering just cutting them off now haha
1/8/2017 1:25 PM
Don't do that...
1/8/2017 4:44 PM
use fire to get them off
1/8/2017 5:00 PM
As mentioned up-thread, get a crank arm puller. I use the Park CWP-7. Less than 14 USD. Worth every penny and then some.
1/11/2017 7:46 AM
I took it to my local bike shop and his puller couldn't latch on to anything to work, so guessing it's just not coming off
1/11/2017 8:06 AM
Heat them up then hit them off
1/11/2017 8:22 AM
Sounds like there are no threads, or they're stripped—in either case you're SOL with a puller.
Get a torch (or whatever your people call it tongue ) and heat up the crank arm around the spindle, then go back to banging the snot out of it. If that doesn't work... die grinder.
