?NORMAL?
5/23/2009 8:46 AM
Is it normal for your sprocket and back hub driver to not be perfectly alingned?
WILBERT HERNANDEZ...
5/23/2009 9:10 AM
Will anybody help me???
5/23/2009 9:11 AM
um idk but i think thats not right
massholes 4 lyfe!
bstick
legendsx23
5/23/2009 9:21 AM
If your sprocket and driver aren't alingned by lets say 2mm,is it supposed to make a big cranking noise even though the sprocket and driver aren't bent?
5/23/2009 9:24 AM
your spacers on your cranks..........you have either too many or not enough....depending on which way the alignment is off.
I'll beat the %@#kin brakes off you @%tch. Shut the %#!k up and ride your %*#kin bike @$$hole.
5/23/2009 9:27 AM
What if you cant take anymore spacers off your cranks or cant put anymore on?
5/23/2009 10:20 AM
5/23/2009 10:23 AM
um then take it to a bike i shop i would say?
i have had that problem just because my bike was a piece.
If you keep running it like that it will eat your sprocket and break teeth then blow out your driveer because its putting so much pressure on the bearings
refs: Spikez5, cokacola, dacumup213 (x2), josh estey, Blake El Gingero, naters14, Harry95, pcoco, hattrckhcky, bstick, kevinl, Sunday.bmx21, dgisback, iridebmxeveryday, I RIDE
5/23/2009 11:17 AM
What if your sprocket and driver were not alinged by just 1 or 2 mm?Would it make a clicking noise?
5/23/2009 1:03 PM
5/23/2009 1:20 PM
5/23/2009 1:33 PM
PS-SUNDAY-COLOR IS G-A-Y/A F-A-G-G-O-T
5/23/2009 2:24 PM
5/23/2009 2:24 PM
5/23/2009 2:28 PM
too many what if's...
Boxman for President
5/23/2009 2:30 PM
IF my sprocket and driver were not alinged by 1 or 2mm and the driver and sprocket weren't bent,would it make a "click" noise?
5/23/2009 2:31 PM
fail
say yeahh.
5/23/2009 2:32 PM
azbmx12 wrote:
fail
YOU FAIL FOR WRITTING FAIL HERE
5/23/2009 2:34 PM
you fail for tellin me i fail for writing fail
say yeahh.
5/23/2009 2:35 PM
Just try to help me will ya?
5/23/2009 2:49 PM
no it should be alligned
5/23/2009 2:51 PM
But will the chain make a clicking noise and skip even if the sprocket and driver arent bent?
5/23/2009 2:59 PM
yes, it still will.
because its putting alot of pressure on your driver and its bendin the chain so just put in/take out some spcers until its aligned
say yeahh.
