Nasty Vibrating Noise
12/27/2013 9:10 PM
So I just built up a new bike and whenever I hit my front wheel from the side it makes a loud vibrating or rattling noise. It's not my headset I've tweaked it many times, I'm pretty sure it's my front hub. Only problem is that I have an Odyssey Antigram and there are no cone nuts. If you need pictures or videos just let me know!!
12/27/2013 9:25 PM
My friend had this and its actually your front rim being too tight in a certain point I believe. Try take it off or get a spoke wrench and fuck with it until it goes away
12/27/2013 9:29 PM
hold your front wheel to the fork and hit it against the ground and see if it still does it, I bet almost anything it's the front hub being slightly loose. A lot of front hubs with press on hardware I've seen have that problem
12/27/2013 9:34 PM
No noise when I do that, is there anyway to fix this? if it helps earlier today I tried to get my hubguard off to try and see if that was the problem but when I pulled on the guard the axle and the bearing that the guard was on came out.
12/27/2013 9:36 PM
One more thing is that my lbs happens to be Empire so if I need some sort of spacer or anything just let me know and I can try it out
12/27/2013 9:39 PM
exactly what I meant
12/27/2013 9:40 PM
Haha
12/27/2013 9:56 PM
See if the bearings can be tapped in a little more, might solve the problem. or take it down to Empire & see what they say.
12/27/2013 10:02 PM
Just by pressing or would a mallet come into play here?
12/27/2013 10:06 PM
Any idea how I can take this guard off? it's stuck good Photo
12/27/2013 10:08 PM
Got the axle out but the guard and bearing came with it hahaPhoto
12/27/2013 10:11 PM
Chances are, your center axle is just a TAD bit longer than your hubshell/hardware. Try spinning your hardware/press fit hubguard with the wheel tightened down and see if they move. If so, your center axles too long. You could try filing your center axle but be careful, only a little bit at a time until it works. If you file too much, your hardware will get pressed into the bearings and keep your wheel from fully spinning. This
is why I hate pressfit hubs. The center axle and hardware have to sit perfectly even with eachother for everything to work properly. I would just take it to empire, and I would imagine theyd give you an all new center axle if you bought it from them. Or maybe your hardware is too short.
12/27/2013 10:13 PM
And set the guard onto something with an opening big enough for your axle to fall into, and use a socket to hammer the axle out of it.
12/27/2013 10:42 PM
place the edges of the guard on something with an opening in the middle so the axle sits there & can fall out, then screw one of the bolts in at least 1/2 of the way into the axle, then tap the head of the bolt & the axle will move down & allow the guard to slide off.
I hate aluminum press on shit, the axle/guard deform pretty quickly. Chromoly center axles/guards rule
12/28/2013 2:00 PM
i use my fork steerer tube for shit like this, works all the time :L
NEW Bike check
Raw Clips Edit
