Need help with choosing pegs & hub guards
2/25/2018 8:03 AM
i need some help with buying pegs and hub guards for my wtp arcade
2/25/2018 8:17 AM
Salt AM pegs will work, and Salt Plus Pro Nylon rear hub guards should work.
That’s basically just sticking with the components that are the same brand as your hub. Most all pegs will fit, but usually hub guards (especially drive side guards) are proprietary.
2/25/2018 8:27 AM
so 4 salt plus pro nylon guards?
2/25/2018 9:34 AM
Yes, but make sure you choose 2 front guards and 2 rear guards if you plan on grinding on both sides.
Front guards will have a bit of a shallower cone shape whereas rear hub guards are a bit deeper to accomodate for the driver.
2/25/2018 10:20 AM
Keep in mind that the rear guards are two separate types. Drive side and non-drive side.
2/25/2018 10:43 PM
Edited Date/Time: 2/25/2018 10:44 PM
Get uniguards front and back. They are universal and protect your dropouts as well.
3/8ths for the front and 14mm for the rear.
4140 chromoly and cheap. Last way longer than plastic too...
