Need some opinions about this MDS
6/14/2013 6:46 PM
I had put an extra washer on before my sprocket because of the inner guard that i cannot use now because of this master link, seems like it messes with the chain alignment and maybe causes my wheel to be off center , so i switched it up so the washer is on the other side and i was wondering if any of you think this will cause any un necessary damaged to the sprocket bolt since i cannot tighten it all the way down or it will bent the sprocket
i appreciate anyone's insight on this issue
Albes Is Rad!!!
YouTube
Instagram
Blood Life
6/14/2013 6:48 PM
Albes Is Rad!!!
YouTube
Instagram
Blood Life
6/14/2013 7:03 PM
ya i did that when i was a noob and i fucked my chain and sprocket real fast. like over a coupe months but i didnt grind at the time so it was all pedal pressure. and just pedal pressure on a noob should last a life time.
6/14/2013 7:14 PM
greenbastard wrote:
ya i did that when i was a noob and i fucked my chain and sprocket real fast. like over a coupe months but i didnt grind at ...more
do you think i should put it back the way i had it or keep it like this and try to find a longer sprocket bolt and a washer for the in between the sprocket and the cranks sprocket boss
Albes Is Rad!!!
YouTube
Instagram
Blood Life
6/14/2013 7:19 PM
either put it back (which i would do) or get a longer bolt with a washer same size as the spacer between the 2
6/14/2013 7:24 PM
yeah im thinking about putting it back because having less bolt in there is just a bad idea and doing all that other stuff seems unnecessary to me, i dont understand why i have to do this to have my cranks perfect on both side but then again i got a primo bb kit lol
Albes Is Rad!!!
YouTube
Instagram
Blood Life
6/14/2013 7:27 PM
Edited Date/Time: 6/14/2013 7:28 PM
I think the washer is supposed to go on the back side. Do you have a spacer between the cranks and the BB? What cranks do you have? maybe try to take off the crank arm and sprocket at the same time and i think the crank boss is supposed to sit flush on the indention of the mds. I think it would mess it up i'm not a 100% sure but i wouldn't take any chances. sorry if i didn't help.
6/14/2013 9:21 PM
Mikel8149 wrote:
I think the washer is supposed to go on the back side. Do you have a spacer between the cranks and the BB? What cranks do you ...more
You are correct sir, it's definitely supposed to be on the other side about to switch it back, I have stranger cranks btw
Albes Is Rad!!!
YouTube
Instagram
Blood Life
