Need to know if I should use a spacer or not
1/20/2018 1:34 PM
Edited Date/Time: 1/20/2018 1:37 PM
Ok so I just got my new fork and put it on and need to know if I should use a big spacer or not.Photo
1/20/2018 1:38 PM
1/20/2018 1:38 PM
Use a small spacer.
1/20/2018 1:39 PM
That's a lil to much gap for me, I'd use a smaller spacer and taller bars
1/20/2018 1:40 PM
I run my stem like the bottom pic and I have no issues. With spacers, it's always best to have at least 60% or more of the steerer tube in the stem.. Or at least that's my mentality. Never cracked a stem or steerer tube that way.
BOTTOM TEXT
1/20/2018 1:43 PM
5mm spacer and you're good to go. Or chop the steerer a bit
1/20/2018 4:54 PM
get a smaller spacer, you definitely don't want that big of a gap but without any spacer the cap will bottom out on the fork and your headset won't get tight.
1/22/2018 12:05 AM
Yep like a 1/4 incher.
1/22/2018 1:10 PM
You need to be able to tighten your compression bolt, and it doesn't look like you can without adding a spacer. 2-5mm should be fine.
