New Tires for Rims help
3/17/2017 1:14 PM
Bought a 2016 Haro Annex Expert for my son. It came with 28h Alloy double wall DA16 rims (don't know brand of rims). The tires are Kenda "Kompact" K1054 20x1 3/8". Can I put 20x1.75' or 20x1.95' tires on it? Thanks in advance.
3/17/2017 1:23 PM
Edited Date/Time: 3/17/2017 1:24 PM
Yes, you can.
The 20 in 20" x 1.75" refers to the rim/tire diameter. The 1.75 in 20" x 1.75" is the tires width. In other words, anything with a 20 in front means it'll fit any 20" rim.
For an added example, a 24" x 2.25" means that a tire fits 24" rims and it's width is 2.25" wide.
The width is how wide, or how "fat" a tire looks. There are advantages and disadvantages when it comes to running either a skinny or fat tire.
With a skinny tire, anything below the 20" x 2.10" range, in my opinion, will be fast with little rolling resistance, but landings may be a bit rougher since there isn't as much cusion as a fatter tire.
On the other hand, a fatter tire, maybe around 20 x 2.30" or even 20 x 2.50" will be very good for softer landings, but may slow you down with all that rolling resistance.
3/17/2017 1:56 PM
Would they fit on the rim? Sure, probably. Are they suitable for that rim, and, indeed, the bike itself? I don't know. That's a race bike you got there. If those rims are Alex DA16 rims (seems likely?), then they're considerably thinner than what the community here rides. I don't know at what point a tire becomes "too wide" for a given rim, so I can't help there, but also be mindful of the frame and fork and will the larger tires rub on on even one of those areas.
3/17/2017 1:57 PM
I'm not so sure the rim might be too small to accommodate a 1.95 tire. It might but I'd suck with a better set of 20x 1 3/8' tires
3/17/2017 6:49 PM
Tryed this in the 80's..
Answer is: it will fit the rim Intel you ride.
20x1.75 tire works for a while,then the tire will peel off the rim. The depth and with of the rim is to small (shallow). Which causes the beed to slip off. 20x1 3/8 are a race rim. Has some flex to them and easy to bend
Best advise
If you want to have a wider tire look for a 20x1.75 wheel set
F¬ Bom 5403692331
3/17/2017 8:13 PM
Not trying to downgrade that bike , but swap tires as soon as possible . Rode them a couple years back and every 360 even when landed clean , the bead would fly off the rim and it was constantly on both sides . Horrible tires
3/17/2017 11:47 PM
20x1.3/8ths isn't the same as 20, a "normal" bmx tyre probably won't fit (the same way 700c, 27x1.1/4, 28x1.3/8ths are all different. A new road tyre won't fit an old rim from the 70's/early 80's). Tioga make the powerblock in 20x1.3/8ths though, have a look at that
