New frame has diff bottom bracket than old frame
12/22/2016 3:07 PM
Just got my new frame that uses a mid as opposed to my old frame that was american. Do I just need to buy a mid bb kit and I'll be good to go? Don't wanna buy the kit just to realize I should have ordered cranks too or something. Also any recommendation on a kit? Thanks.
12/22/2016 3:47 PM
Just pop the bearings out of the cups for the American BB and the press them into the new frame.
12/23/2016 9:18 AM
That depends on if the bearings in the American are sealed (they most likely aren't, the only frames I ever see with sealed American are the well-made aftermarket from like 2001). Order a Mid BB kid from Empire or something, they aren't too pricy.
12/23/2016 9:45 AM
Remember to measure your axle diameter too, chances are it's 19mm. So you'd need a 19mm mid bb.
The mid was designed (by fbm i might add) by taking profile bearings from the cups and making a shell they'd press fit into. Not all American bb's use the same outside diameter bearing. Primo bb's didn't fit mid frames
12/23/2016 10:09 AM
The bearings I have are unsealed. I'll measure the axle and order a kit. Thanks guys.
12/23/2016 10:49 AM
Super-Pawl wrote:
That depends on if the bearings in the American are sealed (they most likely aren't, the only frames I ever see with sealed ...more
This is true, I am thinking back to when I started and just assumed sealed.
12/23/2016 1:14 PM
The mid was designed (by fbm ...more
I'd like to add mid 22 fits in American BB cups if anyone needs cheap bearing replacement.
12/25/2016 4:24 PM
post a picture the cranks and the crank spindle with the crank arm detached. we can probably tell you what size they are
wallride a bus everyday
12/25/2016 5:27 PM
You will at least need a new spindle, and new cranks depending on the spindle and BB size you choose.
