New rear axle is too big?
9/23/2014 1:25 PM
I bought a new rear wheel and hub since my old one got bent to hell and I didn't realize there we're different axle sizes, my new hub has a 14mm axle, it's the Odyssey V3. I guess my bike is a 10mm? Is there anything I can do so I don't have to buy a new hub?
9/23/2014 2:32 PM
That's not good.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
9/23/2014 2:51 PM
What bike or frame do you have?
Modify it yourself.. file down the inside of your drop outs a bit and make it fit. I've done it to an older bike for the same reason and it worked out fine. Gonna need a good file though and put work into it.
9/23/2014 3:11 PM
It's a haro ZX-24 and I found a conversion axle for the hub that'll convert it to 3/8 so I'll just do that.
9/23/2014 3:15 PM
That conversion wont do you much good if its the one im thinking. If its the 3/8" female conversion kit, it will convert it to a shemale axle, which still requires 14mm dropouts.
Filing it down carefully is your best bet.
Or file the axle nubs off the conversion kit.
9/23/2014 4:40 PM
HardBMX_Tim wrote:
That conversion wont do you much good if its the one im thinking. If its the 3/8" female conversion kit, it will convert it to ...more
Filing off 4MM of material is quite a bit though..
9/23/2014 4:44 PM
Then you better start looking for a 3/8" rear hub!
9/23/2014 4:56 PM
Well I'll have to return the wheel I guess cause I bought it complete, how sketchy would it be filing it though? Would I be weakening the structure at all?
9/23/2014 5:10 PM
Zerokateo wrote:
Well I'll have to return the wheel I guess cause I bought it complete, how sketchy would it be filing it though? Would I be ...more
Ofcourse you will, but unless youre doing huge drops or crazy gaps i believe youll be alright. Personally, i would buy the axle kit for it and file the axle nubs on it so it operates like a normal 3/8" female hub.
9/23/2014 5:16 PM
I would just file the drop outs
IG
@curtis_cantbmxwell
9/23/2014 6:28 PM
file the bottom of the dropouts. Not the top. That way your rear wheel will still sit level.
If you have a dad, or know how to use an angle grinder, this is a ten minute job.
9/23/2014 7:29 PM
Take 2mm off of the top and bottom of the dropouts, measure, mark up and cut/file.
If not buy a used ratchet hub and a 3/8" axle./nolt setup.
9/23/2014 7:39 PM
Edited Date/Time: 9/23/2014 7:40 PM
@HardTim, the Odyssey IS a true 3/8" female, not a shemale. It does come with spacers though that would sit in your dropouts if it were a 14mm dropout, however.
See
It would work. At least I think so.
9/23/2014 7:42 PM
sundaybmxRR wrote:
@HardTim, the Odyssey IS a true 3/8" female, not a shemale. It does come with spacers though that would sit in your dropouts ...more
Huh! Look at that.
9/24/2014 11:17 AM
use a 4-1/2in grinder with a grinind disk and grind away what you need but make sure you stop and measure to ensure a good fit don't want to grind it down to far. Oh and i have done this before on a loder bike with masiive drop outs so it works just be carefull
pcoco ticaleb
9/24/2014 10:02 PM
I went ahead and bought the conversion, I'd rather not grind or file anything. Too risky for me.
9/26/2014 12:43 PM
So guess what I ordered from Dans Comp and it didn't come as shown in the picture.
Instead of this
So what do I do? Should I call Dans comp even though they removed the item from their website or just grind the fucking nubs off?
