New to BMX Cruiser
7/30/2017 8:22 PM
I just bought a 24" SE Quadangle Freestyle frame/fork.
I have no idea what size Bottom Bracket to buy. Id like to use sealed bearings and I want to use Profile cranks with the Profile Imperial sprocket. Can anyone help Me? Thanks for your time.
Mark
7/31/2017 12:03 AM
That'll depend how old it is. Measure the inside diameter of the shell. If it's 37mm it's Spanish, 37mm with a thread is euro, 41mm is mid and 51mm is American. And profiles have a 19mm axle. So if the inside diameter is 41mm, you'll need a 19mm mid bb etc
8/7/2017 9:39 AM
Edited Date/Time: 8/7/2017 9:41 AM
I could be wrong but I think the 24" Quadangle "Freestyle" came out in 2015.
http://www.sebikes.com/archive/2015/quadangle-freestyle-24
http://bmxmuseum.com/bikes/search?q=quadangle&year-start=1967&year-end=2018&wheelsize%5B%5D=4
COLOR(S) Aqua
FRAME New 2015 Frame Design, 100% Cr-Mo Tubing, Classic Double Downtube, Standing Platforms, Limited Edition & Individually Numbered
FORK Full Cr-Mo Standing Gear
CRANKSET SE 3-pc Cr-Mo, Closed-End Invisibolt, 180mm, Sealed Bearing American BB, 25T Alloy SE Bubble Sprocket
PEDALS SE Nylon Fiber
CHAIN KMC Z410A
WHEELSET SE Alloy 36H 3/8" F & 14mm Semi-Sealed R Hubs w/ Double-wall Rims, 10T Driver, Stainless Spokes, Rear Alloy Washers
TIRES Kenda K-927 24" x 2.125" F & R
BRAKES Promax SEU-961, U-Brake, Linear Pull, For Wide Tires, F & R
BRAKE LEVER Promax SEL-427, 2-Finger Hinged Alloy, F & R
HEADSET Tange ER 1-1/8" Threadless
HANDLEBAR Cr-Mo Power Wing Cruiser Bar, 28" x 7"
STEM Retro Alloy Top-Load w/ Engraved SE Logo & Lightweight Cutouts
GRIPS Oakley B-1B, Custom Colorway, w/ Donuts, Made in USA
SEAT SE Lightning Blitz Seat w/ Bottle Opener
SEAT POST Retro Fluted Micro-Adjust Alloy, 25.4mm
EXTRAS SST Oryg Rotor, Vintage Vinyl Retro Pads, Alloy Valve Caps
WEIGHT, LBS/KG 31.60lbs / 14.33kgs
8/7/2017 11:18 AM
Edited Date/Time: 8/7/2017 11:19 AM
The quadrangle has been around forever. If it's newer it's probably a mid size.
I take that back I guess it's American? Just Google the year and search for specs.
8/7/2017 7:04 PM
If its American and you need a sealed kit, LA casa and gusset both sell sealed bearing USA bb kits.
