bobPA wrote:
Back pedal much? You bash a product hard in your initial posts. Continue to bash even after normal people claim to have ridden ...more
bobPA wrote:
Back pedal much? You bash a product hard in your initial posts. Continue to bash even after normal people claim to have ridden them with no issues. Then someone with a big name from the industry provides an explanation and you are now blaming the hub flanges and everything else.
If you don't like/don't believe in a product don't pussy out because someone told you otherwise.
Yeah, but you gotta realize I was pretty much completely delusional when i was posting this. I was real sick and had nothing but a bunch of nyquil and water in me. Rational thought was not really apparent.
I didn't bash it too badly, just stating the problems i did have with it. I did stand by those comments, i just considered his professional opinion.
The truing i could handle. It was like after every... idk like 4 riding sessions i found a hop or thing to true. I'm still not even the HARDEST rider out there. I'm not exactly butter on toast but I'm not so rough or burly that it should've happened. Lacing it was kinda hard but once i got it it wasn't all bad. If i can, i will post the crack on here to show you.
It's still not as strong as a Hazard Lite. I can vouch for that very much so. The rim while i was riding it FELT good, as it was very light and less rotational weight is always a plus.
But as i also stated, i still had less trouble with it than rims from other companies. Shit, i cracked a Primo Seven series a few times, minor cracks, but still it was only in the front and i kept it true pretty well. Along with the Stun rims. Which i may add aren't 110% terrible. None of the rims stated are. They all have their flaws, (except for the Hazard Lites, which i have had no issues with at all).
And as for "pussying out" i get how that looks, but i was considering a professional opinion, who i am willing to trust wouldn't lie to us all. It was laced to a Colony Wasp hub, which is garbage in comparison to the Ratchet hub i have now. Every single time i lace a hub with different sized flanges, it takes longer than one with the same sized flanges. Symmetry is ideal. Not just because of different spoke lengths, but probably due to how the tensions are bound to be different when you have to twist the hub in the process.
I stand by what I have said, as I'm sure a LOT of work went into the product, I was willing to entertain the notion that it may not have been entirely the rim's fault, but more of how it was made originally and the PREVIOUS owner.
I should also state that when i got it, it needed trued, and then i had spoke trouble so i got new ones and once it was laced again it did stay a little better, but not perfect, like i had hoped.
