Odyssey caliburs stuck
6/15/2019 1:01 AM
I’ve been trying to get these pieces of shit out for the past hour and a half and I’ve tried everything from hitting them with a mallet and using the bolt as a crank puller to tapping the sprocket with my mallet to get the arm loose. No bike shops are open since it’s 1am so what should I do. I don’t wanna go to my local bike shop in the morning since they charge $30 for crank installation removal and $10 for BB installation/removal, making it an $80 project
smile
6/15/2019 1:57 AM
WD-40, blowtorch?
6/15/2019 2:18 AM
I'd recommend getting a proper crank arm puller (Odyssey sells one for $15). Kind of a bummer that they wouldn't included one...
6/15/2019 3:28 AM
They have one at my local bike shop but they don’t let anyone touch their tools because someone accidentally fucked up a chain breaker a while ago
smile
6/15/2019 4:14 AM
Use a lighter for some seconds and then hit it again ...
6/15/2019 4:49 AM
Bummer. Once you do get them off I’d recommend going with a set of 8 splines for easy install/removal.
6/15/2019 8:42 AM
1. Did you lather the splines in grease before installing the Cranks?
2. 48-Spline cranks are not the best Cranks to install and try to take right back off. If they're fairly new Cranks, you may need too ride them for a handful of months to break in the splines.
3. Any crank will come off with a properly fitted crank puller and some whacks from a metal mallet.
4. Buy your own tools, then you won't have to worry about paying other people to use theirs.
If anything, it's a good thing that they fit that tight. Means they're less likely to develop wobble.
6/15/2019 11:40 AM
But I ride 9ft quarters sad
smile
6/15/2019 1:17 PM
Edited Date/Time: 6/15/2019 1:18 PM
Make some pasta. Strain the hot pasta water directly onto the crank spindle/arms. Remove by tapping gently with a non dead blow hammer.
Enjoy pasta as a celebratory crank arm removal meal.
6/15/2019 4:01 PM
Heat the crank while lowering the temperature of the spindle.
That should work like a charm.
How to achieve this though...that I do not know laughing
