My wheel is occasionally 'biting' and causing my pedals to turn when I'm coasting (and have my feet off the pedals), and I'm having a lot of trouble diagnosing it (seems heavily, maybe entirely, dependent upon the tightness of the 'cone nuts' or the last nuts that go on before inserting the wheel into the dropouts), but one thing that's noticeable is that the driver's bearing isn't very free-spinning at all. It's not particularly rough, but it's certainly far from what it should be. It works, it rides proper enough, but if I put my bike upside down and spin the rear, it spins 1/20th as long as the front (plus the (occasional) previously-mentioned 'ghost pedalling' where i'll be coasting and the driver grabs the hub, pulling the chain and then the cranks along with it (very lightly, a gently pressure stops the cranks from moving)
I have a fantastic-condition kink wheel, I've used its spokes&nipples to build this new lhd wheel, and am now wishing I could take its driver's bearing out and put it in the new driver - if that's not possible, can I at least open up and service the bearing in my ody driver? I remember rollerblade&skateboard bearings had a clip, you'd pop it then pull off the faceplate - I don't see that ring on these bearings, I see two outer edges and an inner plate, all I can think is to try to, what, pry it out with a thin knife, then bang it back under the lips of the outer&inner borders of the bearing?
Any help on approach would be greatly appreciated here, as well as other thoughts (supposedly there's another brand driver that'd fit my vander lhd? Since 1 of my 4 pawls is kinda worn, that wouldn't be the worst idea, but am really trying to get new guard sprocket & pegs asap so can't really go all-out on other parts right now....)
Thanks in advance for any help!!
